Removing emmisions?
Smog pump uses very little power, less than 5 hp, and the unfiltered air is going into the exhaust. Never heard of any problems caused by that and smog pumps have been around 50 years.
That's not to say if the stuff isn't working and you don't have to pass an inspection that the smart money is on removing it and getting rid of exhaust leaks etc.
then you will have no problem finding the right belt and the wrap around each of the rest of the components is correct.
<cite>www.arb.ca.gov/msprog/aftermktcat/installcatq&a.pdf</cite>
I assume you mean this.
"Q. What is the penalty for a violation of the law?
A. Catalytic converter falls under California anti-tampering law. The law is designed to prevent tampering with pollution control devices on California vehicles. The anti-tampering law is Vehicle Code Section 27156 and covers all pollution related systems and devices on a motor vehicle. A violation of this law may also include a parallel violation of California Business and Professions Code Sections 17200 and 17500. Judges usually impose penalty based on the severity of the offence and whether a repeat offender is involved, and a fine of up to $2,500 for each violation may be assessed, as well as some jail time."
...This seems to be a jailable offense under the trade practices law. i.e. if you are a dealer or shop that has a history of disabling emissions control devices, but NOT a felony. (punishable by a prison term of over one year)
And further, here, http://www.arb.ca.gov/enf/sb1402/policy.pdf
on pgs.11-12 (under "Mobile Sources and Fuels Penalties (Part 5 of Division 26, HSC)" we see
"... Part 5 relies almost exclusively on civil penalties.
Transactions involving new motor vehicles that are not certified to ARB’s
emission standards are subject to civil penalties of up to $5,000 per vehicle per
violation (section 43154). These are the hallmark penalties that safeguard ARB’s
stringent motor vehicle emission standards. They were upheld in State Air Resources Board v. Wilmshurst (1999) 68 Cal.App.4th 1332, which
rejected many of the legal challenges to ARB’s ability to enforce its vehicle
certification programs.
Other requirements carrying specific penalties for violations selling
vehicles that violate ARB’s emission standards [$5,000 per vehicle (section
43211)], violating ARB test procedures [$50 per vehicle (section 43212)] and
tampering with pollution control devices ($1,000 per violation for car dealers
(section 43012)]."
Cite: Health and Safety Code Section 43012 Vehicular Air Pollution Control
I'm not looking to argue.
It's definitely against the law, and obviously I can't condone it...
I am pointing out someones wholly mistaken belief that for an individual modifying their own emissions system is a felony under State or Federal law..
Long story short I removed the pump and used a shorter belt. The 5.8L engines used several different belt routing schemes, some are easier to get working with a shorter belt, others are not. No Check Engine Light, no loss of mileage or any driveability issues for the last three years since I did the swap.
The D3VE heads are not tapped 5/8-11 like the windsor heads are.
If the engine was out you could drive in 49/64th freeze plugs like those found at the front of the heads. (NAPA # 219-2188) or tap the inner step of the hole 1/4"NPT and use plumbing parts.
Someone makes a plug for these that is held in place just like the end of the crossover tube is.
But I don't have that link here on my netbook.
