Bushing Help.
Old Apr 1, 2012 | 06:11 PM
PRIMERED79 SHORT BED's Avatar
Bushing Help.
Is this how you assemble the front bushing on a 79 f series?
[IMG][/IMG]
I ordered these from LMC and i was also wondering if i was missing anything?
Old Apr 1, 2012 | 09:20 PM
Will i need this as well?
Body Mount Sleeve, Upper
LMC didn't have it in their catalog, so checking if its necessary.
Old Apr 1, 2012 | 09:45 PM
bkohne1's Avatar
bkohne1
Yes, you do need that or you can just make your own. I made my own by having big washers made and welding a nut to the bottom of one and then using 3/4" black pipe to run through the center.
Old Apr 1, 2012 | 09:57 PM
How did you run 3/4" pipe in the top bushing?
The hole in mine seems like it would be a tight fit.
Old Apr 2, 2012 | 04:51 PM
bkohne1's Avatar
bkohne1
It fit in mine. Measure the I.D. and see what it says.
Old Apr 2, 2012 | 04:55 PM
bkohne1's Avatar
bkohne1
Somebody had a real nice how to thread on here for doing this kind of fabrication. I cant find it now but it is here somewhere.
Old Apr 2, 2012 | 06:51 PM
Its a tight 3/4" that why i was asking, I'm still not entirely sure how you all installed the 3/4" pipe, does anybody got a pic handy?
I searched the forums before i posted, and i couldn't find anything on how to install these bushings.
I thought i had all the parts till i was messing around on JBG and seen the upper piece.
Old Apr 2, 2012 | 08:20 PM
BignastyGS's Avatar
BignastyGS
I have absolutely no bushings or hardware for my truck. The ones from the donor cab were torched and of no use and I know the ones on the truck are killed. Are the ones in the first picture the cab mounting hardware from LMC?
Old Apr 2, 2012 | 08:39 PM
Yes Sir.
I'm just trying to get a mental visual of how these guys are using the 3/4" pipe.
Oh BTW how long is the pipe?
earthquake68's Avatar
earthquake68
Correct me if I'm wrong, but isn't that already IN the upper bushing you showed us a picture of? It looks like it to me. Then the lower bushing slides over the nub sticking out and gets drawn tight with the washer/nut combo on the bottom. How many sleeves did you want to put on each body mount?
Old Apr 2, 2012 | 08:42 PM
bkohne1's Avatar
bkohne1
The ones in my truck had a upper and lower sleeve that pressed together. I am trying to remember though if the front (radiator support) had two sleeves or just one sleeve and a cap like what you have pictured....I cant remember though.
Old Apr 2, 2012 | 08:45 PM
That's what i was thinking, i ordered everything from LMC that they had shown in their catalog.
I was wondering if it was a new design or knock off of the ORG.
The one on bronco graveyard is different, and according to the posts above i need it, but i don't know how it will all fit together.
Old Apr 2, 2012 | 08:51 PM
This mount is for the front drivers cab mount.
I'm loading a pic for you all to see.
Old Apr 2, 2012 | 08:52 PM
Here's a better view.
[IMG][/IMG]
Old Apr 2, 2012 | 08:56 PM
bkohne1's Avatar
bkohne1
That looks like it has both sleeves.
