1985 F150 - starting issues
It's a custom rig and the tank's not original. The original bed was removed, and stainless steel bed frame was put in with wooden boards making the bed and a wood frame making up the side rails. It's actually pretty cool looking! I've not yet been under to know where the HP pump is. I'm guessing the pump in the tank is still good. I'll take your advice and check the hoses. Hopefully, that will be a fairly simple fix.
Thanks!!
Thanks!!
When it's acting up next time...take that cap off and push in on the needle. See if you have good fuel pressure up there. This will tell us if this is even a fuel problem or not. Do this before you start taking hoses off under the truck...may save you some time...or at least let us know we're on the right track.
Might even want to do it when its not acting up to give you and idea of what the pressue is supposed to be like. Careful not to spray gas all over a running engine though. cover it with a rag and press it quickly
woodsmoke
13
09-19-2017 07:45 PM
dnkensinger
08-14-2016 11:49 PM
dragon250
06-07-2011 11:30 PM
