1985 F150 - starting issues
Old 04-01-2012, 09:22 PM
82f100460's Avatar
82f100460
82f100460 is offline
Originally Posted by sgauvry
It's a custom rig and the tank's not original. The original bed was removed, and stainless steel bed frame was put in with wooden boards making the bed and a wood frame making up the side rails. It's actually pretty cool looking! I've not yet been under to know where the HP pump is. I'm guessing the pump in the tank is still good. I'll take your advice and check the hoses. Hopefully, that will be a fairly simple fix.
Thanks!!
when you troubleshoot next time, see if you can't get it to repeat the issue. Get it warmed up and to the point where it don't want to start hot. Before doing this, see if you can find that Shrader Valve on the fuel system up in the engine compartment. Looks like the valve on your tire. Should be a cap on it as well to keep dirt out
When it's acting up next time...take that cap off and push in on the needle. See if you have good fuel pressure up there. This will tell us if this is even a fuel problem or not. Do this before you start taking hoses off under the truck...may save you some time...or at least let us know we're on the right track.
Might even want to do it when its not acting up to give you and idea of what the pressue is supposed to be like. Careful not to spray gas all over a running engine though. cover it with a rag and press it quickly
Old 04-02-2012, 05:18 AM
sgauvry's Avatar
sgauvry
sgauvry is offline
That also sounds like very good advice! You guys are the best!!
I won't have time to fool with it until next weekend. I'll let you know then.
Thanks again!
woodsmoke
13
09-19-2017 07:45 PM
dnkensinger
08-14-2016 11:49 PM
hreyesg
10-03-2013 08:23 PM
dragon250
06-07-2011 11:30 PM
mac10guy
17
06-14-2010 09:14 PM
Quick Reply: 1985 F150 - starting issues
