Headlight Switch Issues!!!
Old Mar 31, 2012 | 11:20 PM
Kaizer88's Avatar
Kaizer88
Got a 89 f150, replaced the switch the female end (that plugs into the switch). I am still having the same problem.... When I pull the switch out only the headlights work, I have to push the switch in a lil bit to get the parking light and tail lights to come on with the headlights. When I pull the switch out to just the parking lights they dont turn on. Please help!!!
Old Apr 1, 2012 | 01:02 AM
Spktyr's Avatar
Spktyr
Did you replace the switch or the switch end of the harness?
Old Apr 1, 2012 | 06:28 AM
Kaizer88's Avatar
Kaizer88
sorry i was tired when i wrote the post... i meant to say i replace everything the switch AND the female end that plugs into the switch
Old Apr 1, 2012 | 01:00 PM
Speicher's Avatar
Speicher
Ck. fuse #4, 15 amp at the fuse panel, feeds Tan/White wire to the headlamp switch. The switch should feed the Brown wire while in both tail and headlamp positions.
Old Apr 1, 2012 | 09:17 PM
Kaizer88's Avatar
Kaizer88
Ill be damned... It was that fuse. Thanks for the help
Old Apr 1, 2012 | 09:56 PM
Speicher's Avatar
Speicher
You're welcome, glad you got it.
80f250ranger
Apr 22, 2013 06:08 PM
klemklubfoot
Oct 6, 2010 11:53 PM
cableguy657
Electrical Systems/Wiring
Oct 30, 2009 07:54 PM
knash0727
Sep 13, 2008 06:04 PM
orangeford
Mar 18, 2003 06:22 AM
