Sponsored by: Real Truck
Lift ????
Old Mar 31, 2012 | 11:21 AM
bigbadgixxer's Avatar
bigbadgixxer
Lift ????
I have a 8" donahue lift on my 03 f350 cc 4x4 v10. the nose sits lower than the rear by about 1.5" - 2" i was thinking about front lift shackles to even it out? any suggestions or advice?
thanks
Old Apr 1, 2012 | 07:41 AM
Furian's Avatar
Furian
You Keep What You Kill
Rather than raising the front I would consider lowering the back... Does your rear axle have blocks? If so, then I would install smaller blocks or remove the blocks to level the truck.
Old Apr 1, 2012 | 12:25 PM
bigbadgixxer
thanks i believe it has stock blocks? how do i know this? can i measure the block or does it say ford somewhere? also where did u buy your SCT livewire tuner i want 1 too w mikes tunes u can pm me if u like? also love the height and wouldnt mind raiseing the front unless shackles r bad? appreciate the info
thanks
Old Apr 2, 2012 | 10:56 AM
Furian's Avatar
Furian
thanks
Here are the F350 OEM 4" blocks on my truck. My suspension is completely stock.
I purchased my SCT Livewire from 5 Star Tuning several years ago. If I were purchasing a tuner today, I would select the SCT X3 tuner with custom tunes to save $$$.
I can't advise you on the shackles but hopefully other FTE members will chime in...
floridahonky
Competition
Jun 12, 2010 12:19 PM
abriel68
Mar 9, 2010 08:39 AM
jetch114
Jul 16, 2007 12:10 PM
amcjrb
Jan 15, 2005 05:48 AM
rtalich
Sep 16, 2003 02:11 PM
