6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
NEED HELP PULLING WATER SEP. SENSOR
Old Mar 30, 2012 | 12:51 PM
DD2000GT's Avatar
DD2000GT
My water seperator drain drips instead of flowing and now my water in fuel warning light is popping up on my dash. Drained multiple times, so based on what I have read here sounds like my water seperator sensor is gunked up. Going to try to remove and clean, then reinstall - but cannot find instructions anywhere to do this. I read it is easy - but are looking for instructions by those that have done this.
Can any body help?
Old Mar 30, 2012 | 05:58 PM
senix's Avatar
senix
Attached is a pic of the offending piece you are talking about. As you can see the bolts in the pic they are easy to remove.
there should be a gasket once you remove the plate.
If you go to your parts dealer (Ford) they should have the gasket for it. Get that before you start.
Be sure to elevate the front end so you don't get so much fuel coming out when you take it apart.
File Type: pdf
rory1269
Jul 19, 2015 09:45 PM
bryanzzz
May 15, 2015 02:54 PM
robert421960
Apr 2, 2012 10:02 AM
Dyllan78
May 7, 2011 01:48 PM
tex25025
Mar 6, 2007 11:22 AM
