head gaskets went
Old Mar 30, 2012 | 10:55 AM
turbo diesel fan's Avatar
turbo diesel fan
head gaskets went
ok i noticed my head gaskets went. when i start my ride i notice white smoke coming out the exhaust. and ive noticed small amounts of fuel in the oil. so im thinking rebuild time? and i cant seem to find a rebuild kit for the idi with turbo. can someone help?
Old Mar 30, 2012 | 10:58 AM
91dirtydiesel's Avatar
91dirtydiesel
you in auburn wa?
so do you have any water in oil or oil in water? or are you just guessing that becuase the smoke just so happens to be white? the lift pump or injection pump can cause the fuel to get in the oil...and the white smoke could be a few things....does it run rough when started or at all?
Old Mar 30, 2012 | 11:44 AM
IDIDieselJohn's Avatar
IDIDieselJohn
Even if it is a blow head gasket, no need for a rebuilt, just pull the heads off, replace gasket, and away you go!
But x2, we need more info!
Old Mar 30, 2012 | 11:47 AM
turbo diesel fan
no sir auburn illinois and john ive noticed my diesel is somehow getting in my oil? needs rings?
Old Mar 30, 2012 | 11:49 AM
IDIDieselJohn
That could be 2 things, bad seal in the IP, or the diaphragm in the mechanical lift pump went bad.
Old Mar 30, 2012 | 11:53 AM
turbo diesel fan
dirty diesel we guessed it was diesel because the oil was black and at 10 quarts and not holding more. but it was milky and i drove it another week and lastnight ive noticed it was blowing white exhaust everywhere. the more fuel delivered to the cylinders the worse it was blowing the white smoke.
Old Mar 30, 2012 | 11:55 AM
turbo diesel fan
ip? and the mechanical pump went bad awhile ago i now have a different fuel pump some one stuck on
Old Mar 30, 2012 | 12:02 PM
IDIDieselJohn
IP = Injector Pump. Those can leak fuel into the crankcase to is the seal goes bad (witch is pretty rare) but can happen.
Old Mar 30, 2012 | 12:07 PM
turbo diesel fan
either the ip needs replaced or the rings are wearing down i have 273,000 on it and only had to replace the radiator and water pump. i just noticed a slight milkyness in the oil was guessing diesel because oil was pure black not brown
Old Mar 30, 2012 | 12:29 PM
turbo diesel fan
i tried to post a picture but it didnt work of the fuel pump that pushes my fuel to the fuel wheel
Old Mar 31, 2012 | 12:48 AM
eatont9999's Avatar
eatont9999
If your oil is milky at all, it is coolant. Diesel fuel in the oil would only raise the oil level and thin it out, plus smell a little like diesel fuel. If that were the case, the only possible smoke it would cause would be grey or black and that is assuming it is too full and being sucked through the CDR or past the rings.
What does the exhaust smell like? If it has a hint of a sweet smell, it is burning coolant. There are several issues that can cause coolant to enter the cylinders, so we need to know more, first.
Old Apr 16, 2012 | 08:32 AM
turbo diesel fan
I havent smelled the exhaust. When it starts it puffs white and has a small white vapor when idling. Heard it was head gaskets so i decrieded to replace them to see if it solves tje problem
That One Fat Guy
May 3, 2012 09:20 AM
WPBronco
Jan 23, 2006 09:08 AM
herothc2003
Dec 19, 2004 11:52 AM
DutchmanAZ
Dec 22, 2001 12:22 AM
FORDTRUCKMAN1976
May 20, 2000 05:35 PM
