self checking codes
Old Mar 29, 2012 | 08:54 PM
kid chuckles's Avatar
kid chuckles
self checking codes
I am having surging problems on a 94 f150 4.9 standard 5 speed 2 wheel drive single cab. Fresh rebuild on motor.
Does not start well and have to rev up to get to idle after starting. When driving it runs up ok but surges pretty bad at a steady Speed.
I took to Auto Zone to get codes checked. Code 522 was the only one that came up stating it was not in neutral or park while doing this.
I came home did the self test and same thing. Does anyone know if the clutch might have to be pushed in while running these tests? It seems if it is saying not in park or neutral, and it won't start without the clutch pushed in then maybe it has to be. I had it in neutral parking brake on.
I am so lost trying to figure out why it is surging while holding the steady speed i could spit.
Also how do you check fuel pressure and where? What type guage do i need? Thanks in advance fella's.
Old Mar 30, 2012 | 04:49 AM
EPNCSU2006's Avatar
EPNCSU2006
Yes, the clutch should be held to the floor when running the test on trucks with the 4.9L engine.
Old Mar 30, 2012 | 07:42 AM
subford's Avatar
subford
X2 ^^^
To check fuel pressure you need one of these:
You can get one at:
http://www.amazon.com/Actron-CP7818-...3111648&sr=8-3
Here is where you hook it up, the "Fuel Pressure Relief Valve":
Then you need to ground pin #6 of the self-test plug or short it to pin #2 and turn on the key:
Self-test plug location:
You should get between 55 & 60 psi on the gauge.
Old Mar 30, 2012 | 08:10 AM
rla2005's Avatar
rla2005
Forget about running the KOER tests, run the Key On - Engine Off (KOEO) tests and CM display first. Once you have any issues in those tests resolved then focus on the KOER tests.
datree
29
Jan 13, 2019 08:12 PM
timf150
15
Aug 9, 2014 08:10 PM
jimthib1
30
Sep 26, 2012 07:08 PM
A/Ox4
Dec 26, 2011 04:42 PM
supr_sly
Feb 28, 2010 10:36 AM
