no start help
Old Sep 11, 2012 | 12:10 PM
jimthib1's Avatar
jimthib1
no start help
truck cranks good but no start i have checked the spark and it is good the truck will start and run if i spray fuel in the intake but dies soon as i stop its a 1989 f150 5 speed 300 i6
things i have replaced plugs wires cap rotor
idle air control , tank pump and frame pump fuel filter and fuel regulator none of this has helped im stumped
Old Sep 11, 2012 | 12:49 PM
subford's Avatar
subford
Well first off you need to ground pin #6 of the self-test connector and turn on the key to see if the fuel pumps run all the time the key is on.
Old Sep 11, 2012 | 04:13 PM
jimthib1's Avatar
jimthib1
sorry it took so long to do the test i had to go out yes the pumps ran with the key on and the test lead in .
Old Sep 11, 2012 | 05:12 PM
Freightrain's Avatar
Freightrain
Push the schrader valve on the fuel rail and see if you have fuel pressure. Maybe the regulator has failed?
Old Sep 11, 2012 | 06:34 PM
subford's Avatar
subford
Does the pumps run for one second and quit each time you turn on the key with pin #6 NOT ground?
If NO then either the computer is bad or the computer does not have a good ground or there is no voltage to it.
If no, start by checking the small black wire with a green stripe at the NEG post of the battery. If this wire is not there it will not run. This wire may be married to another small black wire with a white stripe. Also look at the radiator support in front of the battery for these wires as they may be bolted to the support with a larger wire running back to the NEG post of the battery.
Old Sep 12, 2012 | 06:30 AM
jimthib1's Avatar
jimthib1
yes the pumps come on and run for a second with the key as they should/also there is fuel at the valve
Old Sep 12, 2012 | 07:48 AM
subford's Avatar
subford
Sounds like the computer is not getting the PIP train from the Distributor.
OR
The injector wiring is open to the computer or the red wire is not powering the injectors.
Check with a test light on the red wire at any injector.
OR
There is a blockage in the fuel supply lines or the fuel pressure regulator is stuck open.
Check with a fuel pressure gauge at the fuel rail.
Also check that the EGR valve is not stuck open.
Old Sep 12, 2012 | 09:13 AM
jimthib1's Avatar
jimthib1
red wire has 11.7 volts on it when the key is turned on <battery is little low have been working on the truck for a few days now >
fuel pressure is all new parts but looks like i will have to buy a pressure gage to make sure its not that none of the parts stores around here lend them out any more .
how would i check the pip out of the distributor?
and thanks for the help on this bud its making me nuts lol
Old Sep 12, 2012 | 09:23 AM
Lead Head's Avatar
Lead Head
Since you have power at the injectors, you need to find out if the computer is firing them. Put your multimeter across both injector wires on an injector. With the key on run, it should read 0 volts. With the engine cranking it should pulse 12v. If your multimeter is not fast enough, you'll need to go to an auto parts store and rent a solenoid/'noid/injector test light. It should blink if the computer is firing the injectors.
Here's a way to find out if the computer is receiving a PIP signal: First turn the key on and verify the 1 second fuel prime. Then you'll want to crank the engine briefly and once you let the key go (leave it at RUN, don't turn it off) listen carefully for the fuel pump. After the engine stops rotating, the fuel pump should continue to run for another second.
Old Sep 12, 2012 | 09:34 AM
subford's Avatar
subford
Originally Posted by jimthib1
<battery is="" little="" low="" have="" been="" working="" on="" the="" truck="" for="" a="" few="" days="" now="">how would i check the pip out of the distributor
You would have to unplug the computer plug and put an LED across the pins in the plug that the pip comes in on and ground (56 PIP & 16 IGN GND).
You can use the LED in the photo below but would have to put different ends on the LED than in the photo to get on the pins in the computer plug.
Then crank the engine and see if the LED flashes.
</battery>
Old Sep 12, 2012 | 09:38 AM
jimthib1's Avatar
jimthib1
ok its getting the pip did the test and the pump runs for a secound after you stop cranking looking more like the computer and yes my multimeter is to slow to test that with
Old Sep 12, 2012 | 09:42 AM
subford's Avatar
subford
Good idea but make sure the engine makes a complete revolution as the computer will not ground the injectors or run the fuel pump until it has.
Old Sep 12, 2012 | 10:02 AM
jimthib1's Avatar
jimthib1
did the crank test again cranked the motor a good long time and the pump ran soon as i stoped
Old Sep 12, 2012 | 10:05 AM
Lead Head's Avatar
Lead Head
That means the computer is receiving a PIP signal, however it doesn't mean that the wiring between the injectors and the computer is fine. You'll want to check continuity between the injector wires and Pins 58 and 59 on the computer.
Injectors 1,3,5 go to Pin 58, while injectors 2,4,6 go to Pin 59. If the wiring is good, I'd still check the injectors out with a test light and see if the computer is pulsing the injectors. A bad sensor could cause the computer to not inject enough fuel - or low fuel pressure could also cause similar issues,
Old Sep 18, 2012 | 03:29 PM
jimthib1's Avatar
jimthib1
sorry it took so long to get back to you guys had to wait for days off to come back around fuel pressure is at 53psi checked the continuity on the wires from the injectors and there all good got a pluged in a fuel injector test light and no signal
