Acceleration Lag
Old Mar 29, 2012 | 07:31 PM
ch803's Avatar
ch803
Acceleration Lag
I have a 1965 Ford F100 with a 300 L6.
Was driving it down a road and all of the sudden it started "coughing".
I thought it was my fuel level but after I filled it up, as I thought that was the problem, it continued to do it. So I checked all Spark Plugs and they still have a spark. Installed new wires, new coil, new distributor cap, new plugs. It still persists I cannot figure it out. Now every time I accelerate from a standing stop it lags or lacks power. Checked the Carb as well and there is fuel reaching it. It has a bit of an erratic idle as well. If you have any ideas to what it might be please let me know thank you.
Old Mar 29, 2012 | 08:02 PM
schoo's Avatar
schoo
you need fuel- spark at wright time- compression ck---!
cough not lite back fire?
is distributor bolted tight?
Old Mar 30, 2012 | 02:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bogging down, hesitating, stumbling from a dead stop or when accelerating at speed: Time for a carb overhaul, the accelerator pump is his-tor-ee.
Old Mar 30, 2012 | 04:25 AM
fordpt's Avatar
fordpt
Probably a vacuum leak. Did you not put new points and condenser?
Old Mar 30, 2012 | 11:35 AM
ch803's Avatar
ch803
I will check the tightness of the distributor bolts thanks.
I figured it needed a rebuild going to try this. I did put in new points and a condenser its got to be the carburetor. Ill check thanks.
ericjacobs
Jul 29, 2019 02:17 AM
LuckyLobo59
19
Mar 27, 2017 06:26 PM
72##ford
Oct 9, 2014 03:31 PM
trouble454
19
Jan 30, 2011 03:09 PM
Dan64F100
Jun 25, 1999 05:04 AM
