After my engine is started for a min the oil cap shoots off and oil spits out of the dipstick! any input on what to do? its a 223 straight 6. much appreciated. i know its a combustion issue but thats all i got.
thanks guys. i gonna check the compression as well. i was told there is a air flow tube coming out of the back of the engine somewhere.... cant seem to locate it.. thanks for the feedback.. definitely going to put this advise to use. thank you!
crankcase pressure.... lost..... broken rings? it starts but then the oil cap and the dipstick shoots out with a thick cloud of white smoke.... any ideas? about to give up....
thanks for that. coolant huh? i borrowed a compression gauge from auto zone but they dont have the right adapter..... if its a broken ring or theres a hole in my piston, do you think i should just get a new engine?
There is no such thing on any a 223 I-6 or 262 I-6 as original.
PCV was mandatory in all 1961 and later vehicles sold new in CA, but may/may not have been mandatory in other states till circa 1966.
When vehicles from other states came to CA, if PCV not present, a PCV kit had to be installed before the vehicle could be registered.
Factory installed PCV: The valve cover has two holes, one for the oil cap, the other for the smog valve which fit into a rubber grommet.
Neoprene rubber smog hose routes from valve to 90 degree elbow which threads into brass fitting that threads into backside of carburetor.
If the carb has been replaced, it's possible the PCV system was removed. CA smog tests were once required for all 1950 and newer vehicles.
But the smog laws were changed 30 some years ago, so now it's 1976 and newer vehicles.
Look for the DSO code that is stamped on the Warranty Plate, located on the left door face below the latch. If DSO code is 71 or 72, your truck was sold new in CA.
Thanks number dummy. So that is a pcv valve. I knew it but wasn't positive. Can't get one of those new. You know if a "little" air is supposed to be blown out of that or "a lot" I tried cleaning it out but there's a pretty small tube inside that thing. Took the valve cover off and there's a plate tack welded over the pcv inside the cover. That's good info you just gave me.
Can't get one of those new. Sure you can, how many would'ja like? You just need to know what other vehicles/engines the valve was used on, know where to look for it.
D8TZ-6A666-B (replaced: C4AZ-6A666-A, C5ZZ-6A666-A, C7OZ-6A666-A & B, D0OZ-6A666-A, D7TZ-6A666-A) .. Smog Valve (Motorcraft EV-49-B) / Available from Ford.
so the #1 valve has no compression.... the top end was just rebuilt so thats good. bottom end rebuild i guess. i got quoted 1400$ out the door for new pistons, piston rings, gaskets, oil pump w/ a 1200 mile and 1yr warranty... whata you all think??? sound good or not so good?? thanks guys
