vacuum help please
Old Mar 29, 2012 | 12:38 PM
peshewa's Avatar
peshewa
vacuum help please
Hello, newbie here. I am working on a 25 passenger van for my church. It's a short bus I guess & it is a 1987 with a 7.5 liter engine. I have done some searches on this forum, but can not seem to find exactly what I need. A previous mechanic removed the air pump & re-routed all the vacuum lines on it. It runs really rich & you can smell gas while driving on the highway with it. I see uinder the hood there is a vacuum diagram, but I do not understand the various abbreviations & need help with them please. I also need to know if there is an alternate version of vacuum routing after the air pump is gone. I know what is there has to be wrong since the vacuum block on the thermostat housing has nothing on it at all & that is only for starters. I hope I posted here in the correct forum. My local dealership has no info on this engine because of it's age. Please help!
Old Mar 29, 2012 | 02:46 PM
subford's Avatar
subford
Take photo of the vacuum diagram and email it to me and I may try to help you. My email address is below in this post.
I take it that this is a carb 460.
Here is a few of the abbreviations:
AIR BPV = AIR ByPass Valve
CPRV = Canister PuRge Valve
CARBON CAN = CARBON CANister
EVR = Egr solenoid Vacuum Regulator valve assembly
EGR = Exhaust Gas Recirculation valve
SOL V = SOLenoid vacuum Valve assembly
MAP = Manifold Absolute Pressure sensor
VRESER = Vacuum RESERvoir
MAN VAC = MANifold VACuum
DIV = air DIverter Valve
FPR = Fuel Pressure Regulator
PCV = Positive Crankcase ventilation Valve
TAB = Thermactor Air Bypass vacuum solenoid valve
TAD = Thermactor Air Diverter vacuum solenoid valve
TCP = Throttle temp ComPensating valve
IAS = Intake Air Solenoid
ACV = combination air Bypass/Air Control Valve
CPRV = Canister Purge Regulator Valve
SV-CBV = Solenoid Valve-CarBuretor bowl Vent
TVV = carburetor fuel bowl Thermal Vent Valve
PV = Power Valve
BV = Bowl Vent port
MAN VAC = MAiN VACuum source,
A/CL DV = Air ControL DiVerter valve (Carb heat valve)
VVA = Venturi Vacuum Amplifer
VDV = Vacuum Differential Valve
VCV = Vacuum Control Valve
VCK-V = Vacuum Check Valve
CARB = Carburetor
DIST = Distributor
TK = Throttle Kicker
LARIAT 85
Nov 6, 2010 04:08 PM
Kans_Geo
Aug 31, 2010 05:09 PM
Gunner33
May 11, 2009 07:08 AM
fishindave11
Nov 14, 2008 09:46 PM
bronco bj
1978 - 1996 Big Bronco
Feb 24, 2002 02:55 PM
