auto trans shifting
Old Mar 29, 2012 | 10:25 AM
bctimber's Avatar
bctimber
auto trans shifting
1999 f350 v10 i just got this truck and it did shift good before i change the hood grill and front drivers fender ?. now no speedometer it shifts like the old c6 did whth no vackum to the modeler . when i first went i notice the anti lock brake light on and 5 mins later the check eng light. have i knock a wire off , fuse or rely. thanks Shane
Old Mar 29, 2012 | 11:14 PM
bctimber's Avatar
bctimber
OK have changed the vss sensor and the conneckter pulg. still the same . abs light on no speedo and shifts hard HELP
Old Mar 30, 2012 | 07:34 AM
stuart1's Avatar
stuart1
Without knowing or seeing what was done any advice would be iffy.
Look at all electrical connections or a squashed wire.
Check the fuses too.
Why were those pieces replaced?
Old Mar 30, 2012 | 09:31 PM
bctimber's Avatar
bctimber
OK found the problem.I thought it was an non ABS with just an VSS on the diff. after digging around in the bottom of the driver side fender I found some cut off wires went to the passenger side same thing, went to the wifes 03 same colour code wires go to the front diff. some $@%&^% has cut all the ABS out of the front diff. Is there any way to bypass the front abs so i have a speedo and the trans to shift properly
Old Apr 3, 2012 | 07:25 PM
Karjalanwarrior's Avatar
Karjalanwarrior
Maybe previous owner changed hubs and cut wires? do you have correct hubs with abs sensors? Or bad sensors? if you need sensors I have both front sdnsors from my project. Changed new hubs on my f250 . Should fit yours.
tjc transport
May 18, 2015 12:01 PM
twobeer
Jul 16, 2006 02:52 PM
rgthoma
Aug 31, 2005 06:37 AM
Rayos460
Aug 14, 2004 08:57 PM
jamesbell
Jul 20, 2003 08:39 AM
