speedometer/abs problem
Old Jun 14, 2003 | 07:39 AM
jamesbell's Avatar
jamesbell
Lightbulb speedometer/abs problem
Problem started yesterday ABS light came on out of the blue on the interstate. About an hour later started shifting hard from 1st to 2nd, noticed speedometer lagging. 2000 Ranger Trailhead 3.0 AT. Any and all suggestions welcome.
Old Jun 14, 2003 | 11:49 PM
steve83's Avatar
steve83
Read this thread. If you find a parts store that pulls codes free, it'll probably tell you what the problem is.
Old Jul 12, 2003 | 09:27 PM
fishface's Avatar
fishface
To James Bell,
I own a 2000 Ford F350, 4x4 w/ powerstroke diesel, auto trans.
Similar occurrence - ABS light lit up and is still on, overdrive light on transmission shifter blinked off and on for about two minutes and then went back to normal, speedometer does not actuate until I reach about 20 MPH??????????? Have not taken it in for service yet..have check fuses......OK, have checked brake fluid level.......OK. I don't have a clue, anyone out there with similar problems and a solution? Please advise....Thank you
Fishface
Old Jul 12, 2003 | 09:40 PM
jamesbell's Avatar
jamesbell
Thumbs up speedometer/abs problem
FOUND THAT MY PROBLEM IS THE REAR DIFF SPEED/ABS SENSOR.
IT CONTROLS ABS SYSTE, SPEEDOMETER, AND TRANS SHIFT POINTS. I THINK PART OF MY CAUSE WAS PULLING A LOAD AND DIFF WAS LOW ON FLUID AND CAUSED SOME MINOR FOAMING/HEAT IN DIFF. WENT TO FORD PAYED $15.90 FOR ABS/SPEED SESOR AND 10 MINUTES OF MY TIME. ONLY TOOL I NEEDED WAS 3/8 WRENCH. GOOD LUCK!
JAMES
Old Jul 13, 2003 | 10:49 AM
fishface's Avatar
fishface
Smile speedometer/abs problem
Thanks James. I will research your fix. Where is the sensor located exactly? Did you need to top off you differential fluid to prevent a similar occurrence? Thanks again for your help.
Fishface
Old Jul 13, 2003 | 11:04 AM
dreyfuss's Avatar
dreyfuss
I have had the same problem with my sensor. It triggered transmission problems, abs light, and speedometer fluctuations. Muddy Bronco recommended pulling the sensor on top of the rear differential and wiping off any excess metal flakes from the magnetized sensor and trying that before you buy a new one. It seemed to help me but I find myself continuing to wipe off the sensor often, so I have resigned myself to buy a new one.
Old Jul 13, 2003 | 11:57 AM
jamesbell's Avatar
jamesbell
SENSOR IS ON TOP OF DIFF. I PULLED THE FILL AND DRAIN AND FLUSHED DIFF AND REFILLED WITH ALL NEW SYNTHETIC GEAR LUBE AND HAVEN'T HAD PROBLEM IN 6500 MILES.
Old Jul 13, 2003 | 05:38 PM
MustangGT221's Avatar
MustangGT221
Please take the caps lock off, thanks...
Old Jul 13, 2003 | 09:07 PM
jamesbell's Avatar
jamesbell
Justin sorry about that!
Old Jul 13, 2003 | 09:32 PM
jamesbell's Avatar
jamesbell
Justin I'm new to your site and wish to have a long standing realationship. I plan to build a radical stroker motor for my 2000 Trail Head and just have fun. I have 30 years experience in motor yachts and more than that in car building. I still own my first car and truck, a 1966 HiPo coupe Mustang K block car with A/C, and a 1971 F100 with 428SCJ and sun gear overdrive. I have had great fun on this website and I hope I can further assist.
James
Old Jul 13, 2003 | 11:13 PM
MustangGT221
No problem (about the caps)....I wish I still owned my first truck (totalled last may)....it's in the gallery. Kid ran a red light and murdered it. But I'm back and better then ever with this one, my 2nd (I'm 19). See ya around the boards!
Old Jul 19, 2003 | 06:45 PM
fishface's Avatar
fishface
Talking speedometer/abs problem
James,
The sensor did the trick. Easy replacement job. Thanks. You saved me some serious money.
Fishface
Old Jul 20, 2003 | 08:39 AM
jamesbell's Avatar
jamesbell
Glad to here it keep having fun.
