Help to identify, please
Old Mar 27, 2012 | 04:06 PM
scooterspal's Avatar
scooterspal
In the engine compartment of my 1999 E-350 there is, what appears to be, a tire fill-up air fitting running along side of the tranny dipstick/fill tube.
Can someone tell me what that is for?
Thanks!
Old Mar 27, 2012 | 04:21 PM
95e150CW's Avatar
95e150CW
I'm fairly sure that is the fuel pressure testing port, but i might be wrong. I'll have to peek under the hood of my 06 and see if its there.
Old Mar 27, 2012 | 08:56 PM
Bbasso's Avatar
Bbasso
a schrader valve?
sure it's not for the a/c?
Old Mar 27, 2012 | 09:19 PM
95e150CW's Avatar
95e150CW
Its a service port for the AC, mine has a cap and a green tag on it.
Old Mar 28, 2012 | 08:42 AM
scooterspal
Are you sure?
AC ports are usually larger and look entirely different than a tire fitting.
Old Mar 28, 2012 | 11:24 AM
WVVan's Avatar
WVVan
It may be the fuel pressure testing port. You might be interested in this posting of mine.
Old Mar 28, 2012 | 11:28 AM
klinquist's Avatar
klinquist
Originally Posted by scooterspal
Are you sure?
Typically there are two AC ports on vehicles - one larger and one smaller. One is the high pressure side, the other is the low pressure side. The larger one is way bigger than a tire schrader valve, the smaller is about the same size as a tire schrader valve.
Old Mar 29, 2012 | 06:46 AM
JWA's Avatar
JWA
Are you sure?
This what you're seeing Scooter?
mudmagnet63
Jun 12, 2016 07:34 PM
LARIAT 85
Feb 18, 2015 02:46 PM
trk pny
May 26, 2013 09:56 PM
SneakyF350
Nov 9, 2012 06:26 PM
John Thomas II
Jun 5, 2003 06:03 PM
