Offroad & 4x4
4x4 problems
Old Apr 29, 2003 | 07:07 AM
BigB4000's Avatar
BigB4000
4x4 problems
I am having a problem with my 4 wheel drive. The front drive shaft turns, I hear it go in and the light is on in the dash, but I have no 4x4. The back wheels will spin, but I get nothing from the front. Could it be the transfer case or maybe the vacuum lines. I have auto locking hubs by the way. Please help me out, I went to the beach this weekend and got stuck. It was pretty embarrassing. thanks
Old Apr 29, 2003 | 07:30 AM
BLMracing's Avatar
BLMracing
4x4 problems
Sounds like a broke lockout hub, or auto hub but I dont know what you have.
Old Apr 30, 2003 | 01:46 PM
fordmudrunner2020's Avatar
fordmudrunner2020
4x4 problems
The same thing happend to my dad's F-250 and my friend's F-150 it is the hubs that broke.
Old May 1, 2003 | 09:19 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
4x4 problems
If your front driveshaft is spinning, then your transfer case is good. I agree with everyone else here, you most likely have a blown hub. You most likely have a front open differential. If only one hub locks in, the differential will send all the power to the one that will spin easier (i.e. the axle shaft of the wheel that isn't locked in). Just like if you get a 2wd truck stuck somewhere and a tire is lifted off the ground, only that one will spin. I hope this helps you. BigB400 could you tell us about your truck like model, transmission, etc.
Old May 1, 2003 | 11:51 PM
13hondacr250's Avatar
13hondacr250
4x4 problems
Auto hubs are known for failing after they get older. Vaccuum lines loose there seal and then your screwed. If theres no grinding sounds coming when you do that no damage is done. But I'd invest in manual hubs. There more reliable and a lot of time stronger.
Tyler
95 F-150 302 5 Speed 33x12.5 rubber
94 F-250 7.3 Diesel 5 Speed
altonlee
Jun 10, 2016 04:35 PM
tjgalinski
Aug 28, 2015 08:42 AM
pcpotter1023
Jul 7, 2015 10:21 PM
dpty22
Jan 25, 2013 01:04 AM
myfree7
Nov 26, 2010 03:35 AM
