360 to 351M
Old Mar 26, 2012 | 08:20 PM
lay4900's Avatar
lay4900
360 to 351M
What will I need to change to put a 77 351m into my 76 F250 with a 360???
Old Mar 27, 2012 | 09:23 PM
HIO Silver's Avatar
HIO Silver
Most everything... tranny, ICM, brackets, etc. Do you have a complete 351M to start from or are ya piecing it together?
IMO, it's not worth it to go to a puny 351M... a 460 is a better choice dollar-for-dollar.
Old Mar 27, 2012 | 10:02 PM
Ohiocrewcab's Avatar
Ohiocrewcab
Hio states it best. my question is why ditch the 360?
Old Mar 27, 2012 | 10:12 PM
79_effie's Avatar
79_effie
Thta's what I was thinking. And I'm a big proponent of the "M" block engines. If it were mine I'd throw a 390 in there. (428 maybe?)
Old Mar 27, 2012 | 10:17 PM
Ohiocrewcab
For about 300-400 bucks you can make the near extinct 410 merc engine, it's a nice little 360/390 stroker. Nice torque and still is not a killer on gas.
Old Mar 28, 2012 | 05:07 AM
lay4900's Avatar
lay4900
Because the 360 is dead. I was told that I only needed to change the bell housing, not the whole tranny. I found an awesome deal on a complete 351m.
Old Mar 28, 2012 | 07:55 AM
Ohiocrewcab
You didn't specify the detail of auto or manual. Yes if it's a 4-speed then yes just the bell housing. Unless you are being given the 351m and all the stuff to do the swap it might be easier and cheaper to find a 390 or 360. They are around.
Old Mar 28, 2012 | 07:56 AM
Poison Oil Racing's Avatar
Poison Oil Racing
while changing the bell housing may solve that problem you will still need different engine perches/mounts, exhaust, maybe radiator hoses? Did you get all of the accessories (alternator, power steering pump, a/c, etc.) with the 351m? They may be different and/or require different mounting brackets.
What you are asking is doable, but might be a lot of work.
Old Mar 28, 2012 | 08:09 AM
thunder74-79's Avatar
thunder74-79
ive done this swap for a guy only using a 400 instead and come to find out the juice isn't worth the squeeze. It can be done but as others have stated you need the towers mounts exhaust all the accessory brackets a different starter. You can use the rad hoses from the 360. Does the 351m come with a flywheel or a flexplate? Cuz you may need that too. I'm sure there is more that i'm leaving out but this is basics to get it in the truck anyway.
Good luck if you decide to do it, good boy if you don't.
Old Mar 28, 2012 | 08:37 AM
lay4900's Avatar
lay4900
Thank you everybody. Yes it is a manual trans. And my starter is hangin up now so I'd need one of those anyway. I'm not swapping for power, I'm swapping because the 360 died and I can find a 351m cheap and quick. This is a project truck but also not a weekend driving truck. I really do appreciate all the help.
Old Mar 28, 2012 | 08:51 AM
bamaf150's Avatar
bamaf150
If its a project and you dont need the truck to get around, I think you would be much better off rebuilding/stroking the 360 to a 390, much happier preformance wise as well. You say the 360 died, is the block ok?
Old Mar 28, 2012 | 08:56 AM
lay4900's Avatar
lay4900
I meant project being it needs a lot of work, but yes it is my second vehicle. I don't know if the block is any good or not yet. I will probably have it checked out because they are so hard to come by. But as I understand they aren't in high demand are they?
Old Mar 28, 2012 | 09:06 AM
thunder74-79
you may want to just think about redoing the 360 if salvagable and as bama said make it a 390. Well worth the effort imo
Old Mar 28, 2012 | 09:41 AM
bamaf150's Avatar
bamaf150
FE blocks arent really too hard to come by, they arent on every street corner but its not like they are rare either. Where in Florida are you?
Old Mar 28, 2012 | 09:55 AM
lay4900's Avatar
lay4900
Tampa, Lakeland area
