NEED HELP
Old Mar 26, 2012 | 05:10 PM
twages's Avatar
twages
Cool NEED HELP
I have an 1967 F-100. I am trying to fix the turn signals and break lights. O'reilly told me that the flasher relay has been discontinued. Not sure how else I could fix this. If anyone could help that would be awesome. It might also be easier if someone coulld call me.
Old Mar 26, 2012 | 07:27 PM
jowilker's Avatar
jowilker
Turn signals & brake lights share the same wire & bulb filament. I like to start at the rear of the truck. You need a circuit tester. Do you have one?
Start by removing the lens cover, removing the bulb & test it. if nothing, move under the truck unplug the wiring harness about 6" from the tail light, test it, follow the wire to see if a trailer wire has been added in. move on to the end of the drivers side frame rail, unplug the connection there testing all of these moving forward.
Report back after doing these steps. You may have found the bad place. Oh by the way check for blown fuses under the hand brake lever first.
John
Old Mar 26, 2012 | 07:47 PM
allwthrrider's Avatar
allwthrrider
First off what exactly is the problem
Old Mar 26, 2012 | 09:07 PM
twages's Avatar
twages
I will let you know thanks
Old Mar 27, 2012 | 09:27 PM
twages's Avatar
twages
Power
John
There is no power from the tail light to the dash. No power at all.
Would it be possible if someone could call and help over the phone?
Old Mar 27, 2012 | 10:37 PM
Ford_Six's Avatar
Ford_Six
Well, all the brake light and turn signal power goes through the turn signal switch in the steering column so that's a good place to look next. Brake lights and turn signals get their power from different fuses, so barring both fuses being bad the switch is a good possibility. I don't have a wiring diagram handy but I'm sure someone else will be able to help with the specifics of diagnosis.
srae03
All Things Towing
Nov 26, 2011 06:48 PM
RobsOld72
Oct 8, 2010 06:35 AM
coolguy1419
Sep 20, 2010 06:45 PM
Redmanbob
Nov 19, 2006 08:33 AM
Bronco2guy
Bronco II
15
Mar 25, 2003 07:02 PM
