fuel in coolant?
Old Mar 26, 2012 | 04:32 PM
muscle66's Avatar
muscle66
fuel in coolant?
Well, she has been running great until for no apparent reason my upper radiator hose decided to rub on my alternator pulley, making quit the mess. This is when i noticed my coolant. It looks weird. I had changed to the gold stuff about 2 years ago, and have never had a cooling problem. It smells a little like diesel, and it looks weird. Its not gelled up, but honestly it looks like someone spit a big loogey in it. Its gold with some kind of whitish stuff floating in it, but is super slick, and when you touch it it feels like regular antifreeze. Does anybody know what this could be? I check my fluid pretty regularly. It has never been over-full or low. I was about to flush it and replace it, but since i dont know what is going on, i dont want to just waste the antifreeze. Any ideas? Thanks guys.
Old Mar 26, 2012 | 07:33 PM
bryanlindborg600's Avatar
bryanlindborg600
could be injector cups? how many miles on her? others will chime in soon!
Old Mar 26, 2012 | 07:59 PM
fordpride's Avatar
fordpride
Two ways fuel can get in the coolant 1. Injector cups 2 internal crack in the head
Old Mar 26, 2012 | 08:01 PM
fordpride's Avatar
fordpride
Drain the oil to see if it has water in it
Old Mar 26, 2012 | 08:18 PM
muscle66's Avatar
muscle66
man that sounds horrible... and expensive... Does anybody know what fuel looks like in the antifreeze? She has 225,000 miles. I have only put about 40000 on her, and replaced just about everything since i brought her... except injector cups. If it was a crack in the head, would she still run so well? I mean I get 18 mpg, and I am very heavy footed. How bad is fuel in the coolant? I mean I have noticed for a while that one of the injectors may not be working right. How much does replacing the cups normally run? Unfortunately, despite the expensive education, my marine biology job really barely pays the bills. I am pretty good at fixing things, but from what i have read, this is pretty intense. This is the worst part about living in Florida now, I dont know any good diesel mechanics down here.
Old Mar 26, 2012 | 08:19 PM
muscle66's Avatar
muscle66
no water in oil. What does that mean?
Old Mar 26, 2012 | 08:27 PM
excavator's Avatar
excavator
the cups can be replaced easily with heads on engine. There is a nice tool available to make job easy. Jim Rosewood the sponsor here from Rosewood diesel has them for sale
Old Mar 26, 2012 | 08:54 PM
fordpride's Avatar
fordpride
Clay at riffraff diesel rents the tool out.
I don't think you have a crack in the head I think you have injector cup issue. He only way to check is to pull the injectors
Old Mar 26, 2012 | 08:57 PM
fordpride's Avatar
fordpride
Old Mar 26, 2012 | 08:58 PM
fordpride's Avatar
fordpride
Click on the blue
Riffraff Diesel: Motorcraft 7.3L Injector Cup Kit
Old Mar 26, 2012 | 09:01 PM
excavator's Avatar
excavator
there is a newer tool that does not require removing the rocker's as well
Old Mar 26, 2012 | 09:04 PM
fordpride's Avatar
fordpride
Yea that the tool clay has. I just post the vids to give the op a idea of what it takes to change the cups
Old Mar 26, 2012 | 09:09 PM
muscle66's Avatar
muscle66
thanks guys. I really appreciate it. So if i am removing the injectors, then this would also be the time to install new ones? I dont have the money, but if did... then since everything will be apart, this would be the best time?
Old Mar 26, 2012 | 09:23 PM
fordpride's Avatar
fordpride
You will need new injector orings to put the injectors back in. Do not use the part store ones only use alliant orings you can get them from riffraff, ford, or international.
I don't know what yor budget is but Rosewood diesel can rebuild your injectors back stock or to stage ones starting at $500 if all internal parts are in good shape
Old Mar 26, 2012 | 09:28 PM
ReBilld's Avatar
ReBilld
I just ordered o-rings from Riff Raff, Clay is great to deal with!!!
