Best Electric Brake Controller?
Old Mar 26, 2012 | 07:36 AM
cj45lc's Avatar
cj45lc
Originally Posted by BigAlsPSD
I'm not much help as I don't have one, but if I was in the market for a new controller to replace my Tekonsha Voyager, which serves me well for nearly being antiquated, I would be getting a Prodigy P3, installed one in my brothers truck and really seems nice, aside from every towing or RV forum it seems to be the "winner".
This is where I'm at also, I wish my Voyager would mess up so I could justify getting the P3. The damn thing has been in my '79 then '86 & now my 2000 & it does just what it is supposed to do. So I just keep saying "if it ain't broke don't fix it" but I would like to have one of the newer models. Everyone that I know that has one says the P2 or now the P3 is the way to go, maybe someday I'll join the 21st century...lol
Old Mar 26, 2012 | 09:32 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
love my P3...easy to see....easy to adjust....great controller....
Old Mar 26, 2012 | 10:21 AM
kawcrasher's Avatar
kawcrasher
Same deal for me. The bad thing is people don't deem them good enough to pull when junking car and the local yard lets me have them for $5. I think I have 4 now.
Originally Posted by bfife
I guess I'm the odd man out. I have a Brakesmart. Absolutley love it. Unfortunately they are no longer in business. Should I have to replace it, I'll probably go with the MaxBrake. very similar to the Brakesmart. It uses actual brake pressure to signal the trailer brakes. Trailer brakes are applied with the same force as the vehicle brake. no leveling, no hassle, works in reverse, no lock up when going down or uphill.
automaticlly checks the trailer when you plug into it, so it knows how many axles, and what type of system its hooked to.
link here:MaxBrake™ - Hydraulic over Electric Variable Brake Controller
Barney
I didn't know anything like this still existed anymore. I had one in my 83' and they where great. I was under the impression ABS put an end to them. Maybe inertia controls caught up to them performance wise then priced them out of the market?
Old Mar 26, 2012 | 10:43 AM
Journeymaaann's Avatar
Journeymaaann
I am in the market for one and once again you guys have helped me make my choice! I also identify with you Dennis that there are few times when I am able to help and it is a great thing when I get the chance because of all the help I have received from this brotherhood.
Old Mar 26, 2012 | 10:44 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by jtharvey
I think you may have accidentally missed those features on the website...listed below.
Features:
  • Applies power to the trailer brakes in proportion to vehicle's deceleration when brakes are applied
  • No level adjustment necessary - it adjusts itself to varying terrain as you drive
  • Works proportionally in reverse - great for backing into tough spots
Specs:
Dimensions: 3-5/8" (W) x 4-5/8" (L) x 1-3/8" (H)
  • Boost levels increase power up 0%, 13% and 25%
  • 180 degree vertical plane operating range
  • Can be mounted between -90 degree (straight down) and 90 degree (straight up)
Having one, I also know that it can be disabled easily for reverse.
Pop, like another member, I switched from a basic U-haul to the P3 and love it. The ease in which it adjusts, how it's adjustable for different sized trailers, and how smooth it applies the brakes is great. I also find the "boost" feature very nice. I've used it on everything from small twin axle trailers to a 30' goose neck where I was grossing 26K, and it works great every time.
Thanks for the info. Are those specs for the P2 or P3? I wish the Tekonsha website had a place for side by side comparisons because I found it difficult to compare features...they all seam pretty close with only minor differences. From what I saw online, the specs for the P2 were
  • Reverse battery protection for both vehicle and breakaway
  • Designed to work with electronic over hydraulic brake systems
  • Numerous mounting options - including 360 degree vertical rotation
  • Digital display depicts voltage delivery to trailer during braking
  • Great for backing into tough spots! Works proportionally in reverse with the ability to disable when not needed
  • Produces stops that are in proportion to vehicles deceleration rate
  • "Boost" feature gives users the ability to apply more initial trailer braking power when towing heavier trailers
  • Continual diagnostics check for proper connection, shorted magnet conditions and much more
  • Quick and easy disconnect feature allows user to remove and store the control when not in use
  • Electric trailer brake control for up to 4 braking axles
  • Limited lifetime warranty
For the P3 the only items they listed were
  • 1-4 axle trailers
  • Distinct, easy to see LCD display with multiple color and contrast options
  • User can customize to choose English, French or Spanish display
  • Allows the user to switch between Electric and Hydraulic brakes
  • Highly advanced, easy-to-understand, roadside diagnostics
  • Easy access, "Up-Front' controls
  • The original "Boost" feature allows for different levels of customized braking
  • Compact, dash-hugging design
  • Unique, easy-to-use, clip-mounting systems
  • Quick disconnect for easy storage; convenient storage pouch included
They did have some videos on their website that was pretty cool but still didn't help me decide which one I wanted to get so I decided to give them a call and see what I could find out. According to the person who I talked to, they said the P3 was basically designed for hydraulic systems but was also backwards compatible for electric brakes as well. It also has multiple languages for the display and the display could be configured in a few different colors.
The P2 had a triple axis accelerometer and was a little better suited for a variety of terrain since it constantly adjusts itself. I think they also said the P2 model was recently upgraded so it pretty much has all the same features as the P3 with the added feature of full 360 degree mounting positions. The P3 had some restrictions on mounting angle, I think the guy said it needed to be within 70 degrees of horizontal if I remember correctly...
When I pressed the person on the phone for a recommendation, he said the P2 would probably be best for my application since I do a lot of mountain towing but he later followed up with a comment saying they both were a premium controller and I couldn't really go wrong either way.
Old Mar 26, 2012 | 01:21 PM
Robert6401's Avatar
Robert6401
Went from a cheap time-delay controller installed by my RV dealer to a P3 a couple of years ago. As far as I know, the P3 is the only one with the level of diagnostic troubleshotting information to help you narrow down a problem, which is what sold me on it. It is MUCH smoother than the time-delay cheapie!
Old Mar 26, 2012 | 01:32 PM
twags6's Avatar
twags6
You could always justify it as a safety upgrade. It'd be like upgrading from drum to disc brakes. Sure, the old one worked, but the new one is better and safer.
Old Mar 26, 2012 | 01:52 PM
cj45lc's Avatar
cj45lc
I hear you bud but every time I think about it I can find a half dozen other things to spend the $$ on
Old Mar 26, 2012 | 04:02 PM
94WhiteF250's Avatar
94WhiteF250
Journeymaaan I know it man, I have asked 50 questions and now I can finally help haha.
Off topic but where abouts on long island are you? I am in northport
Old Mar 26, 2012 | 04:58 PM
hammer65's Avatar
hammer65
I have found that if I want it real bad, then then it is cheap. But if I am not really wanting it, the price is too high.
Old Mar 26, 2012 | 07:30 PM
F350-6's Avatar
F350-6
I've got a Curt discovery. I had used draw-tite controllers for years since they replaced one for free for me many, many moons ago on a unit that was 5 years old. I figured with a warranty like that, why not stick with them. I then needed a new box in a hurry when my draw-tite died. Curt was on the shelf at the closest place so I went with it. I really like it better than my old one. I've used the prodigy controllers before, but don't care for the leveling stuff, and they didn't seem any better than the draw-tite that I had been using.
WOW--jtharvey is in the house!!! man, I haven't seen you here in ages. So good to see that little green light on!
Barney
I saw he posted and had to check the date of the thread to see if this was an old one that got dug up.
Nice to hear from you Jeremy. How's that cummins holding up? Still got the truck?
Old Mar 26, 2012 | 07:49 PM
Orezona's Avatar
Orezona
I have the Prodigy and like it a lot.
Old Mar 29, 2012 | 02:19 PM
  #28
Franko72's Avatar
Franko72
Molon Labe
Originally Posted by SpringerPop
Somehow, that image of Franko and his trailer full of cement igloos comes to mind......
Pop
Sorry I missed this thread Pop You mean the load that killed my transmission...
I got a deal on a UHaul brake controller. (I think i paid $70 for their $130 unit thanks to a friend who worked there)
Its far from the best, but it does what It's supposed to do. I've heard great things about the Prodigy also.
Old Mar 29, 2012 | 03:17 PM
  #29
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Love my prodigy p3. You can move the p3 from one vehicle to another, you just need the wiring plug for the second vehicle. The prodigy works smooth at any speed and any breaking action, plus it will tell you if there is a problrm in the breaking system wiring.
Old Mar 29, 2012 | 03:53 PM
  #30
Crazy_Jim's Avatar
Crazy_Jim
I'm late, but another vote for the Tekonsha P3... That thing works FLAWLESSLY.
