New 6.0 owner
I am the owner of a small construction company and use the truck for service. The truck averages 50 miles of mixed freeway and city driving per day.It has 118,000 miles on it, and I am the third owner. The previous 2 owners had it setup for fleet use as a stake bed; single rear wheel, 4 wheel drive, XL supercab longbed. I got it last week and installed a ladder rack and utility bed and removed the stake bed to suit my needs. It weighs in at 10,300 pounds loaded with tools in this configuration. The turbo was replaced by the dealer as he picked it up broken at an auction. I took the vehicle to a ford dealer before purchase and it was given a clean bill of health minus a power steering fluid change needed. After a week of driving, the alternator died. I replaced it with a 140amp lifetime warranty deal from autozone. It has a rough idle for the first 15-30 seconds after start-up when cold. After it is warm, it starts nicely and has lots of power. Transmission shifts cleanly and firmly, and a very nice upgrade to the unit in the old '99. 3.73. gears, open diff., floor mounted t-case shifter and manual hubs.
I paid $16,000 including tax, licensing, etc. Now, where I need help. Since I knew beforehand that I was going to have a 100k+ vehicle, given my budget and needs, I set aside $1,500 for maintenance upon purchase. I would like to address any known issues and essentially give the truck a clean start. This is mostly for piece of mind as I believe the drive-train is in good condition. I am doing an oil change and probably a new power steering pump tomorrow. The current one whines when I have the wheel maxed out to either side. I know the fluid is bad, but doubt changing it will fix the whine. And even if it does, I know already that the current one has been neglected. Any suggestions on engine oil and power steering brand/type to use in Southern California?
What would be the most important things to do after I'm done with those two?
The price of a new ficm around $1100 or you can have your rebuilt at BPD http://www.bulletproofdiesel.com/Repair_Service_for_your_Ford_6_0L_FICM_p/ficm_rebuild.htm for $300
or--- http://ficmrepair.com/ My choice
Info here http://www.fordtechservice.dealerconnection.com/vdirs/subsites/diag/6.0L_FICM_Guide.pdf
and here http://swampsdiesel.com/site/installation_instructions/pdf_instructions/FICM_Voltage_Testing.pdf
Testing the FICM http://www.youtube.com/watch?v=VSQ9lxr2oN4&NR=1
pop
Your rough morning starts may be a little injector stiction. You can usually help that by using a synthetic 5W/40. A lot of us use Rotella T-6. Costs a little more but most 6.0 run nicely on it. Make sure whatever oil you use is API CJ-4 rated or better. Hopefully you can prolong your injector life by using that oil or another brand with the same rating.
Your power steering unit needs Mercon ATF fluid, NOT power steering fluid. Any Mercon ATF or Mercon V compatible fluid is okay, but I think it is worth using a synthetic like Mobil 1 ATF.
Your transmission needs Mercon SP. You can also use the newer Mercon LV, but personally I am sticking with the SP. I would also use the genuine Motorcraft Mercon SP, not a compatible. The wrong fluid screws these trannys up, per the experts. You need a fluid change every 30k miles, so unless you know when it was last changed, best get it changed to start your ownership.
On a 100k truck, you will want to service the differentials. Again, synthetic is required. Your owners manual gives the spec. Also service your transfer case, which requires Mercon ATF. I used the Mobil 1 synthetic on this too, but that is your choice.
Brake fluid needs to be flushed. Use DOT 3. Do not be tempted to "upgrade" to a later fluid.
Check your FICM volts asap. The rough startup can also be a symptom of low FICM volts. You'll find info on that in the tech folder.
I use a ScanGaugeII its 160.00 and has 30-40 gauges that will pertain to the 6,0L
check it out
www.scangauge.com
other than that change all fluids and start Fresh
Good Luck and Enjoy
What are opinions on the combination oil/coolant bypass filter by amsoil?
Also is this a good idea to get right away, or wait until I need it?
Complete Solution(TM) for Ford 6.0L Powerstroke with Sinister EGR Delete Kit, Oil Cooler, ARP Studs and SCT X3
I want reliability first and foremost. The tuner would be used for the economy program only, perhaps the milder towing program every once in a while too.
pop
Anyhow, I was going to test the FICM voltage today and noticed that the batteries are only 720 CCA. Is this a big deal? And what benefit would I see by going to ones rated at 850?
Also, the specs recommend a 15w40. Benefits to going to a 5W?
Make sure you check the FICM voltage on a totally cold engine. In the morning before the first start up is best.
15W/40 is the standard OEM oil. The 5W/40 has the same 40 weight protection for the engine when it is hot, but the 5W is lower viscosity when the engine is cold. Since your injectors are fired with high pressure oil, they work better with the low viscosity 5W when the engine is first started. The synthetic is also better at resisting breakdown at high temps found in the turbo. Cold injector stiction is the main reason to go with the 5W.
Many of us experienced cleaner cold starts the first day after changing to the synthetic oil.
