Sponsored by: Real Truck
Grease question
Old Mar 25, 2012 | 02:56 PM
Budman1962's Avatar
Budman1962
Grease question
A couple of years ago I had the ball joints replaced on my 2000 f-250. Since then I have been greasing them with valvoline synthetic grease. I recently ran out of grease. I was thinking of switching to amsoil water resistant grease. This is what I use on my jetskis and trailer. Is there any problem with mixing the two greases in the ball joints? It would be nice to only have one grease for everything.
Thanks
Old Mar 25, 2012 | 03:49 PM
bucci's Avatar
bucci
You should know what the thickener is for each one. Amsoil just changed the formulation for their water resistant grease and it is a calcium sulfonate complex. I don't know what the valvoline synthetic is. You could call/email tech at Amsoil for compatibilty.
Old Mar 25, 2012 | 04:46 PM
Kajtek1's Avatar
Kajtek1
Generally all synthetic lubricants are mixable with the dino stuff just fine. If you have the old package you can read the fine print.
Per my knowledge the ball joints don't require synthetic.
Old Mar 26, 2012 | 06:01 PM
Budman1962's Avatar
Budman1962
Thanks for the replies. I'm not sure if the synthetic grease has advantages over the dino stuff like the motor oil does. The mechanic that installed the ball joints used a red colored grease so it may be mixed already. I know I switched my jet skis to amsoil 2 stroke oil and I noticed a performance improvement right away. I thought I would give there grease a try.
Old Mar 26, 2012 | 09:22 PM
Kajtek1's Avatar
Kajtek1
Synthetics shine over dino lubricants at temperatures above 1000 F.
Don't think you have to worry about it on joints
hhcobra
Sep 27, 2011 05:32 PM
t4kne
Apr 29, 2007 09:22 AM
bigdaddyII
Oil & Lubrication
Oct 12, 2005 01:43 PM
MAXEY
Jul 20, 2005 03:17 PM
Tlattin
Dec 29, 2003 09:44 PM
