Hello all i would like ideas as to my next mods. as you can see i have a bunch of mods to my truck as it is listed in my sig i am thinking about going with electric fuel, d66 turbo, head studs and eventually stage 2 injectors 250 cc injectors t500 what do you all think would like some feedback! thanks
I don't see gauges in your sig I'd do them if you don't have em T500 then e fuel. With your stage ones you would notice a difference in the way it runs with the t500
i am also pushing 30 psi on the stock turbo and it starts singing at 2 psi so i would might like to go a lil bigger just would like feed back on the turbo and if my stage 1s will light it up at the right time
i mean the turbo i would like to have a bigger turbo with stage ones since i just got em and i want a lil more power but afraid the turbo will pop so d66 will be fine with the stage ones mine are are 160cc casseroles
The d66 would be perfect for stage ones. Before you buy a d66 check with comp turbo and majestic turbo they cany build our stock turbo to a 66mm turbo for around half of what the d66 cost
