Ive got the stock 275 65 20's, but im interested in going up to maybe a 295 or similar to fill out the wheel well a bit. wanna keep the stock rims also. will my speedo and odo be affected as usual? or is there a way to keep all the numbers accurate?
Actually, the dealers can no longer recalibrate speedometers outside of what is offered as factory equipment. I just went though that issue with my dealer. I have a 3.31 axle ratio. I went from 265/70-17 to 275/65-20. My speedometer/odometer were 7.8% slow (checked w/GPS) after changing wheels and tires. I thought this would be easy. The technician set up my new tire size. We went for a ride to check speedometer accuracy, speedo was right on. During the ride back I got a check engine light. The technician connected the laptop and discover that I had a transmission fault code. A quick google search turned up others that tried to do what I was trying to do. It was suggested to set the axle ratio to 3.55 to get rid of the trans check fault light. That worked. We got the fault code because Ford does not offer 20" wheels with 3.31 axle. Went for another ride to check speedo, speedometer is back to being 7.8% slow. We played with different factory combinations of tire and axle ratios to get the speedometer closer. Finally got the speedometer within 4% slow. We played with so many combinations, I do not remember what we settled with.
Long story short, you are limited to what is on your truck as factory option for speedometer calibration. The tech said they used to be able to set any combination of tire size and axle ratio, but on the newer trucks that is no longer possible. You can also use a Tuner to recalibrate your speedometer, but then there goes your warranty.
Actually, the dealers can no longer recalibrate speedometers outside of what is offered as factory equipment. I just went though that issue with my dealer. I have a 3.31 axle ratio. I went from 265/70-17 to 275/65-20. My speedometer odometer and were 7.8% slow (checked w/GPS) after changing wheels and tires. I thought this would be easy. The technician set up my new tire size. We went for a ride to check speedometer accuracy, speedo was right on. During the ride back I got a check engine light. The technician connected the laptop and discover that I had a transmission fault code. A quick google search turned up others that tried to do what I was trying to do. It was suggested to set the axle ratio to 3.55 to get rid of the trans check fault light. That worked. We got the fault code because Ford does not offer 20" wheels with 3.31 axle. Went for another ride to check speedo, speedometer is back to being 7.8% slow. We played with different combinations of tire and axle ratios to get the speedometer closer. Finally got the speedometer within 4% slow. We played with so many combinations, I do not remember what we settled with.
Long story short, you are limited to what is on your truck as factory option for speedometer calibration. You can also use a Tuner to recalibrate your speedometer, but then there goes your warranty.
Hope that helps.
Thanks, that does help, I did not know that.
Learn something new here almost every day
If you are towing with a tune or using a hot tune, if your egt gets to hot, you will be re and re-ing a turbo and possible heads. Egt is meant to warn you to back out a bit before all the carnage.
