Cab Third Brake Light
Old Mar 23, 2012 | 03:05 PM
1L243's Avatar
1L243
Before I brake it does anyone know if the thrid brake light lens comes apart from the housing? I would like to get in there to clean it...
Old Mar 23, 2012 | 03:08 PM
DemonRace6's Avatar
DemonRace6
Hi!
Yes it does. There are two screws holding it in. You have to be able to get in there to change the bulb.
Old Mar 23, 2012 | 05:47 PM
1L243's Avatar
1L243
I got that far but I want to remove the lens from the housing. It looks like it might be sealed?
Old Mar 23, 2012 | 05:49 PM
HH60FE's Avatar
HH60FE
It comes off, yours might just be "glued" on from not being off in a while
Old Mar 23, 2012 | 05:59 PM
PaysonPSD's Avatar
PaysonPSD
The bulbs in a stock 3rd brake light are a 1/4 turn twist out from the rear. No need to remove lense once you remove the assembly. You can try to clean the lens once the bulbs are removed.
Old Mar 25, 2012 | 12:24 PM
caverjoe's Avatar
caverjoe
Time for an LED from recon.
rutnstrut
Sep 6, 2013 05:26 PM
thehat
1997 - 2003 F150
May 5, 2008 03:35 PM
jmarshall
Feb 17, 2008 06:42 AM
Primered86XLT
Oct 1, 2005 03:09 PM
i_got_2_golf
Aug 5, 2002 12:49 PM
