Going Crazy w/ Third Brake Light
Old Feb 16, 2008 | 09:49 PM
jmarshall's Avatar
jmarshall
1994 F150 Ex. Cab 110,000 miles
I bought this great truck six months ago and need to replace the burned out bulb in the third brake light assembly. I have removed the two screws, but the assembly won't budge. I tryed prying with a screwdriver but it only moves about a 1/2 inch out and kind of snaps back. I don't want to break the plastic and feel there must be some kind of clip holding it inside. The shop manual just shows the screws coming out and the assembly being removed easily. What gives? Thanks.
Old Feb 16, 2008 | 09:54 PM
quicklook2's Avatar
quicklook2
the whole thing pulls out but it is tight.
the center part is what is holding it in.
you need to force it some but not too much.
the plastic red or red/white stays on and the whole black part with the colored lens comes out as one piece.
the wiring goes out at an angle and that is what is holding it.
hope that helps.
Old Feb 16, 2008 | 11:04 PM
TexasGuy001's Avatar
TexasGuy001
Thats true, but also I have seen where the housing melted and there is a bulge in the housing that is holding it from coming out. One of my friends had that happen and the housing or assembly broke when he removed it to replace the bulbs.
Old Feb 17, 2008 | 06:42 AM
jmarshall's Avatar
jmarshall
Both very interesting, thanks. Since I have really pried on the housing, my guess is that it, too, may be melted. The former owner had a topper and had rewired for a brake light on the topper. I removed/ taped wrapped wires when I took off the topper. I wonder if the third brake light is even connected? Thanks for all the information.
