my brain has melted!!!! P0308 code
Old Mar 22, 2012 | 07:24 PM
maxhighlife's Avatar
maxhighlife
<HR style="BACKGROUND-COLOR: #dddddd; COLOR: #dddddd" SIZE=1> <!-- / icon and title --><!-- message -->
I have a 2007 F150 5.4 it has a P0308 code I have put a new set of coils all 8, plugs all 8, injectors all 8, and a new upper intake complete assembly.
after no change I swaped the #8 one at a time the coil, plug, and injector with #1 and the P0308 code always comes back within 5 miles
the truck runs amazing as long as your not in high gear at 40mph -65mph if so it goes to shaking and jerking
has anyone has this issue and found a resolution, Thanks
Old Mar 22, 2012 | 07:28 PM
critterf1's Avatar
critterf1
Have you checked compression on that cylinder?
Old Mar 22, 2012 | 09:17 PM
maxhighlife
it will run 105 in a 1/4 mile and only shows the issue when in 5th gear under a load so I was hopeing someone would say hey thats an easy fix try this but I do know I need to do a compression check b 4 I spend more money, Thanks
Old Mar 22, 2012 | 09:20 PM
Ironhand03's Avatar
Ironhand03
Almost sounds like a piston ring.
Old Mar 24, 2012 | 02:08 PM
2FordTrucks's Avatar
2FordTrucks
I have the same problem. New cop new plug new injector. I'm beginning to think the cat may be bad. I hear a rattling and get a funny smell now. It runs so good at idle and with no load but just stumbles when it has a load. It's frustrating.
SyinSD
1997 - 2003 F150
Nov 18, 2018 10:56 AM
mtmcall
2004 - 2008 F150
Jan 16, 2016 12:48 PM
MIKE 04 GT
1997 - 2003 F150
Apr 8, 2014 05:38 PM
ralphbrad2002
3.8 & 4.2L V6
Mar 19, 2008 06:26 PM
kenbob80
1997 - 2003 F150
Nov 25, 2007 06:34 PM
