07 f250 rearend
07 f250 rearend
I have been getting a lot of vibration when towing ...It seems to be coming from my rearend ..limited slip problem maybe ? I used to only have the problem when i would accelerate heavier than normal when going from a stop to acceleration when making a right or a left ..Now it seems to be gettin worst and more noticeable vibration even when not towing ...I was going to change the rearend oil and see if that helps it at all ...My question is does that differencial cover have a gasket ? and also is there anything to look for while i have the cover off ? Thanks in advance ..
Ron
Ron
Consider installing an '08 aluminum differential cover while you have the cover off. The new cover has a groove for RTV sealant and is an easy installation.
Besides the cover, you will need new (slightly longer) bolts and lockwashers. A search will give you exact details and part numbers.
Lou Braun
Lou Braun
Here's an 05-07 specific rear diff cover replacement thread:
https://www.ford-trucks.com/forums/8...with-pics.html
Great read ...Thanks for the link !
motor-man
1999 to 2016 Super Duty
17
02-15-2010 12:04 AM
