2011 F250 thats wants to be a F350
My 2011 F250 sits almost perfectly level. The back sits 1/2 inch higher than the front. I put a leveling kit on my 06 F350 and loved the look. Does anyone have a recommendation on a company that sells the 4inch block for the rear with a leveling kit for the front? Looking for a great product. Also will be changing out my chappy shocks. Thanks
I am looking to do the same thing with my F250.
I plan on getting the rear blocks and ubolts from my dealership. They are the same price as the ready lift blocks and I won't have to have them shipped.
Which leveling kit are you going with ??
Are you going to do shocks at the same time ??
I am probably going to order the Bilstein leveling kit (with front shocks) and add the rear shocks also.
They use a progressive replacement front coil spring... no spacer.
I posted up asking if anyone else has tried it and so far no responses from anyone that has it.
My996,
Not sure why I never thought about going to my local Ford dealer to buy the rear blocks. Good call on that. I'm probably going to go with Ready Lift's 2 inch leveling kit. Going to go with the bilstein shocks. I'm probably going to do everying when I put BFG tires on this summer. Hopefully air bags next yr.
I'm pretty sure they are 315/65. They are 35" tires. It looked almost level to me before. Maybe 1/2" of rake. I have the snow plow springs on the front and I think they may sit a little higher than the trucks without them.
It still has rake after the lift for towing. The airbags push the rear end up when inflated. They only have 5 lbs in them in that pic.
if you're interested in just a little bit more lift than the previously stated, Readylift also sells the 3.5x3.0 leveling kit for our trucks (http://www.readylift.com/c-228-ford-...r-stage-4.aspx). It utilizes a 5" rear block and a 3.5" front spacer, leaving a little front rake when the truck is not loaded. I'm running this kit with 35" tires, but it could probably fit 36"-37" tires. I have more pics in my garage if you are interested in seeing how it looks.
It will need shining regardless of it being a long bed or crew cab. I had my lift professionally installed and they shimmed it for me. I believe ReadyLift kits come with a shim set. (the lifts that require shimming that is)
