Sponsored by: Real Truck
Front End Wobble HELP!
Old Mar 22, 2012 | 01:02 PM
Dmiller250's Avatar
Dmiller250
Exclamation Front End Wobble HELP!
Ok so I've got a 2000 F250 5.4L V8 2WD. I recently put on 20" Harley rims from a 2007 F250. I had to use 2" hubcentric wheels spacers to make up for the offset difference. The new Harley rims and tires are balanced, tire are in great shape, and have the proper air pressure. When I hit between 40-50mph I get a pretty nasty front end wobble. My truck did not do this until after the spacer/wheel combo. Could the spacers be causing some of the front end geometry to be off? I've also looked at the upper and lower ball joint, as well as the tie rod ends, and everything checks out as fine. Any help would greatly be appreciated.
Derek
Old Mar 22, 2012 | 03:14 PM
Dmiller250's Avatar
Dmiller250
I do hear a clunk when taking off hard from a stop. Could a bad U-Joint cause a front end wobble?
Old Mar 22, 2012 | 06:51 PM
Lou Braun's Avatar
Lou Braun
If you have a poorly machined spacer, or one that is not properly installed, it would be easy to have a wheel wobble.
You can try a front to rear wheel and spacer swap and see if you can locate the problem one. Alternately, jack up one wheel at a time and spin the wheel/tire combination by hand. Check for any wobble or runout. With luck, you can find the problem one.
Lou Braun
Old Mar 22, 2012 | 07:33 PM
FordGuy85's Avatar
FordGuy85
Do the spacers have tapers inside for wheel allignment? Correct me if I'm wrong but some cheaper spacers won't allign properly this not centering you wheel on your hub baring.
Old Mar 26, 2012 | 07:52 AM
Dmiller250's Avatar
Dmiller250
Lou Braun
I've swapped the wheels around and had the tires balanced. I'm beginning to think that spacers are just a bad idea. These are in fact hubcentric and have tapers within the spacer holes so they suck up to the stock studs. I've closely inspected the spacers on the truck and all are seated properly on the hubs. I'm going to try swapping spacers around at this point. This is a very frusterating situation
Old Mar 26, 2012 | 08:46 AM
Dmiller250's Avatar
Dmiller250
I believe I figured out my issue.
The stock hubs have have a lip that the center bore of the rims slides onto. The new spacers have no lip, therefore the rims have some sag (even though very slight) on the lugs. I believe I'll need to take the spacers off of the front wheels or suffer the front end wear that these spacers will cause. Does this seem the the reason my wheels are wobbling?
Old Mar 26, 2012 | 07:15 PM
Dnspream's Avatar
Dnspream
If you know any body with a mill and turn table or a metal lathe you could have them machined down a bit to make that lip. Just a thought..
Brian92390
Oct 20, 2014 04:29 PM
santacruzf250
17
Sep 21, 2010 05:27 PM
samurai
Dec 2, 2008 01:00 PM
BOOTROS
Feb 25, 2005 01:29 PM
beefFX4
2004 - 2008 F150
Oct 11, 2004 09:42 PM
