scariest/most hacked modification
Old Mar 22, 2012 | 08:38 PM
critterf1's Avatar
critterf1
Here lately there seems to be a bunch of dumb-asses born every minute.
Old Mar 23, 2012 | 08:16 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Gary Lewis
And, you wouldn't have to replace the shocks due to wear. But, you would probably have to replace some suspension components 'cause the beating it would take would be awful.
Not to mention the wear and tear on your backside.
Old Mar 24, 2012 | 08:41 PM
Leaf's Avatar
Leaf
On the $300 Wonder Truck....
The crankcase breather hose to the air filter was replaced with a piece of wire loom. I didn't have any heater hose the right size, so I replaced that junk with a piece of clear PVC tubing. It gets alarmingly soft from the engine heat, but it hasn't failed yet...
The oil drain plug is stripped out except for 2 threads and was held in with thread lock. I put it back in with more thread lock. >_> I shall put a junkyard oil pan (it has a big dent in it) on next time I change the oil...
I had a junky old Duster years ago in college that the ignition switch broke on. Since I had no money, I spliced the wiring harness together so it was always "on", and shut it off by popping the clutch and disconnecting the battery cable. The starter solenoid was engaged via a "borrowed" light switch hanging out of the dash. I never used that closet light anyway... >_>
I fixed it all proper-ish later on when I got some summer work, but drove it like that for a good 8 months or so.
Old Mar 26, 2012 | 02:54 PM
fordmanva's Avatar
fordmanva
the fella that won pinks all out in charlotte a couple years ago did so with a pair of vice grips holding on a front brake line.
helped a buddy with a $250 s10 that needed hoses and we ended up wrapping every hose with gorilla tape and he rolled with it for 18 months before wrapping it around a tree
Old Mar 27, 2012 | 02:45 PM
82f100460's Avatar
82f100460
Not on a truck but I picked up a 72' Nova last year that some kid had put a 427 into. Thought it was close to being street ready but soon found otherwise. As I digged into it, I kept finding some hokie stuff so I decided to pull the engine out (mostly due to him not putting the correct frame stands in so the motor mounts didn't line up).
When I pulled it out I found that 2 of the 3 nut/bolts holding the torque converter to the flex plate looked like just something he found on the floor of his garage or out of some coffee can. Then found that 2 of the bolts that hold the flex plate to the crank were missing....guess his coffee can was empty by then.
Glad I pulled it all apart...something was eventually going to come through the floor pan on that thing.
Old Mar 27, 2012 | 07:10 PM
critterf1's Avatar
critterf1
As I was saying.
Old Apr 2, 2012 | 09:02 PM
remy525's Avatar
remy525
I just got my truck, and the radio wiring was all chopped up. ex. 4 wires with butt connectors to form 1 long wire, several wires just twisted together..
Old Apr 2, 2012 | 10:40 PM
Eightyfive Flareside's Avatar
when i got my mud rig (75 chevy blazer, yeah i know chevy) i was having a REALLY hard time trying to get my heater to work right.
Got under the dash after i drove it home and found somebody had unhooked the factory push pull cables from the heater box, and tied hemp rope to them, ran the hemp rover over the hacked out stereo and dangled them under the dash, so you could reach under there and adjust your heater. I have no clue why they did this, all i had to do was hook them back up and it worked, aside from the one level i broke trying to get it to work. I then decided wth id replace the whole unit, got an entire unit, with cables, for 10 bucks at a junk yard.
Next best thing. same truck
I was replacing the headlights in it, had TERRIBLE lights. I was looking at them and i noticed they were in upside down, so i of coarse put the new ones in right side down , well after closer examination, i found my high beams were low beams and lows were high. I popped the hood to see that the 2 wires had been cut off and swapped around. It would have taken more time to swap those wires than to fix the headlights, im assuming somebody wanted brighter dim lights for city driving, but what a way to do it.
Same truck:
When i got that truck home (keep in mind this was a free truck) i immediately went to removing interior parts from the truck, like carpet etc because the top was removed for who knows how long, and the dang carpet had mold n crap in it. So im looking at these side panels trying to understand them, i pull them off to see they are made of 1.5" thick pressed paper interior siding. Yeah it was a little rotten. So i yanked those out, then i found i had like 4 layers of carpet in there too. Pulled that out.
Poor truck
john schmitt
May 12, 2018 02:39 PM
bobj49f2
13
Jan 1, 2015 01:14 AM
tshearer
Mar 20, 2008 08:37 AM
TigerDan
General Automotive Discussion
Oct 14, 2006 12:39 AM
PowerstrokeJunkie
15
Jul 17, 2006 04:14 PM
