Sponsored by: Real Truck
Weird driving noises
Old Mar 21, 2012 | 10:05 PM
jwolfe60's Avatar
jwolfe60
I have a 2001 f250 4x4 with the 5.4 triton and I've replaced the shocks, tires, and both front sway bar links. I still hear a popping/rattling noise coming from the front tire area when i drive on rough roads, I also get a popping noise when I turn sharp, and I have one more weird noise that sounds like running over a rumble strip on the highway that last for just a second and only happens every once and a while driving. Any opinions???
Thanks as usual
Old Mar 21, 2012 | 10:08 PM
jwolfe60's Avatar
jwolfe60
one more thing
I forgot to mention too that side gets hot after driving and has a hot kind of burning smell to it as well
Old Mar 21, 2012 | 11:28 PM
Kdr358's Avatar
Kdr358
Check your front wheel hub bearings and u-joints. Jack up the truck and shake the wheels side to side, up and down. You shouldn't have Any play in the wheel. If you do remove the wheel and spin the hub by hand and listen and look for play and rough spots in the bearing. Good luck!
TayzGpa
2009 - 2014 F150
25
Feb 1, 2019 08:59 PM
blais42
Dec 8, 2014 11:53 PM
SteelerSal
Oct 1, 2013 09:21 PM
Mr.Russell
2004 - 2008 F150
Aug 7, 2008 10:20 PM
timmyp
Dec 5, 2005 09:52 PM
