looking for a tin foil hat (sorta)
Old Mar 21, 2012 | 07:52 AM
jniolon's Avatar
jniolon
old and in the way
I'm searching for something like this... see picture 1
I've found pike nuts (picture 2) but they are a little too pointy
I'll bet this is a one-off turned piece...but maybe one of you might source it
for me. It needs to be stainless if possible..chrome if not and not protrude more than 1-1.5"... diameter is not that important as long as it's proportional..
It's gonna do what picture #1 is doing
all right Sam.... where are they ?
thanks
John
Old Mar 21, 2012 | 08:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Would this work?
https://www.avibank.com/index.cfm?fu....cat&cat_id=38
Old Mar 21, 2012 | 08:20 AM
jniolon's Avatar
jniolon
old and in the way
functionally it would work... but wanting something "tricker" and a little more refined... ya know ??
j
Old Mar 21, 2012 | 08:51 AM
sdetweil's Avatar
sdetweil
thanks
John
sorry for the delay.. will look more
| edit - you could also use the stock hood latch pin.. even in chrome.. MF page 102 - 2013-CH
Sam
BNC Products
'40 Front/Rear clip locaters - GT40s.com
Old Mar 21, 2012 | 09:26 AM
jniolon's Avatar
jniolon
old and in the way
I also found the door mirror bullets.... gonna call and check actual size... those might work nicely...
Old Mar 21, 2012 | 09:34 AM
Jag Red 54's Avatar
Jag Red 54
John, I second the idea of the hood latch. Jag
Old Mar 21, 2012 | 09:55 AM
sdetweil's Avatar
sdetweil
I don't think the screw that holds the bullet/threads will be strong enough the support the impacts of the hood
Sam
Old Mar 21, 2012 | 10:06 AM
jniolon's Avatar
jniolon
old and in the way
Sam
hmmm... hopefully 'impact' is too strong a word... actuators set the hood down gently and the bullet should line up with the grommet in the lower section.. the bullet is just a 'guide pin' I hope... is that part plastic or chromed metal
Old Mar 21, 2012 | 10:22 AM
BACAGrizz's Avatar
BACAGrizz
John,
Why couldn't you chuck the pike nut in a lathe and turn the point to the shape you want?
Short of that how about some of the old hood hold down pins?
Old Mar 21, 2012 | 10:31 AM
jniolon's Avatar
jniolon
old and in the way
Grizz
if'n I had a lathe and knew how to use it... I'd make me some... I'm looking at the chrome hood pins at mid-50 per Sam's suggestion... I gonna worry this till an answer appears...
thanks
John
Old Mar 21, 2012 | 10:43 AM
sdetweil's Avatar
sdetweil
well, driving down the road there are all kinds of wiggles and flexes tht will go on.. I bet there is a bump or two that will add some stresses here & there..
Sam
Old Mar 21, 2012 | 10:48 AM
needhelp49's Avatar
needhelp49
screw back spikes - look here
Old Mar 21, 2012 | 11:22 AM
BACAGrizz's Avatar
BACAGrizz
Drill press and a grinder instead of a lathe? Then have them chromed.
Old Mar 21, 2012 | 11:44 AM
sdetweil's Avatar
sdetweil
and u did think about the other side of this.. the socket they align into.. should be some reliable material.. not just a hole in the fiberglass..
Sam
Old Mar 21, 2012 | 11:52 AM
jniolon's Avatar
jniolon
old and in the way
Sam
looking for a thick walled rubber or vinyl grommet as we speak...
