So, I posted this in the FE forum with 0 responses so far (seems that group isn't what it used to be) so I'll ask here.
I found cast stroker cranks on ebay for half the price of forged ones. Should I go for it or stay away from them? They come in 3.980, 4.125, and 4.250 with no price difference.
I'm also thinking of just putting a torque cam and headers in this thing and seeing what that does. I'm afraid I'd be fighting low compression though. Is there anyway to guess what my compression ratio is without tearing it down and knowing exactly what pistions are in it? I'm guessing it has D2TE heads, either that or C8TE, but I doubt they're C8's.....
Cast cranks are good aslong as your not building a race engine. The cam, headers and air intake will wake it up. And 390's aren't low compression engines, the 360's are. A 390 is somewhere around 9.5ish a 360 is only 7.5.
Weren't the truck 390's about 8.6:1 or so? When I rebuilt my first 390 I used 360 pistons to bump the compression up. It has worked out nicely. My fear is that this 390 in my Highboy is the low compression truck engine, limiting my cam selection. It has been overhauled 10 years ago, but doesn't have very many miles on it.
-Jake
Like Ohio said, cast steel is fine. How often do you hear of guys breaking stock iron crank in truck engines? There are nodular iron ones available too which are stronger than stock and cheaper than steel. When it comes down to it, they all come from the same plant in china so it doesn't matter which one you choose. I was going to use an RPM unit because of the 4.375" stroke.
-Jake
As per factory, the 68+ truck 390's were about the same CR as the 360. I've heard numbers ranging from 7.8:1 up to 8.6:1, but I suspect they were on the lower end of the scale.
In theory, you can swap in a 3.98 crank, using the same pistons/rods from a truck 390, since the truck 390 pistons were the original 410 pistons. This would yield a CR of around 10-10.5:1. Talk about a "cheep" stroker kit....... The aftermarket 3.98 cranks can be spec'd with stock rod bearing size and internal balancing, so no special parts would be needed to keep it from shaking.
-Jake
It is probably low . Ford used different compression height pistons to control compression ratio . Usually a 1.66 or a 1.76 height from the center line of the wrist pin to the top of the piston .
