need help
Old Mar 20, 2012 | 08:53 PM
jammfarms's Avatar
jammfarms
need help
I need an ECU stamp #F1TF12A650CA. It is for a 1992 F--250, 7.3 diesel, e4od AT, 4x4. Local tranny shop scanned and it threw several codes, they said I needed to replace ECU as that many different circuits couldn't go bad at once. Truck will not go into first gear.
Old Mar 20, 2012 | 11:02 PM
RCrawler's Avatar
RCrawler
You need to list the codes that were found. And probably find a more knowledgeable shop to deal with. Could be something as simple as a bad ground causing multiple codes and failures.
Jason
Old Mar 22, 2012 | 08:13 PM
jammfarms's Avatar
jammfarms
Thanks for the help. Found the right part.
Goose52
13
Nov 19, 2020 07:19 AM
jammfarms
Mar 20, 2012 08:16 PM
cmiller1229
Mar 12, 2010 07:33 AM
David1990
May 26, 2006 09:15 PM
7.3burnoutbuddy
Apr 1, 2006 07:43 AM
