Sponsored by: Real Truck
Wheels
Old Mar 20, 2012 | 04:17 PM
JFH's Avatar
JFH
Wheels
Getting ready to lift the truck and put new wheels on.
Any brand suggestions? Or brands to stay away from. I just want a good quality wheel that I won't have to worry about issues in a year or so.
Looking at the black/chrome. I have liked the designs of Ultra, Eagle and KDS.
Old Mar 23, 2012 | 07:36 AM
JFH's Avatar
JFH
Nothing????
Old Mar 23, 2012 | 07:44 AM
Furian's Avatar
Furian
You Keep What You Kill
What is your budget for these wheels? What size and width are you wanting? You mentioned black/chrome... are you wanting the combination of black/chrome or just black or just chrome?
Old Mar 23, 2012 | 07:49 AM
JFH's Avatar
JFH
18x9...would like to keep budget under $200....would go with 20, but I think that's more than I care to spend.
Black & Chrome is probably the way I'll go. I mainly want to know of a good quality company, not necessarily the style. Heard too often of Chrome pitting, or other issues that I would like to avoid.
I like the Ultra Goliath and some of the Eagle & Helo...just don't know if these are quality products.
Old Mar 23, 2012 | 08:14 AM
Furian's Avatar
Furian
90% of the aftermarket wheels are manufactured in China. The quality of these wheels has greatly increased over the last decade. Check the warrantee on any wheel you are considering to purchase.
I see that you live in FL. At least you do not have to consider road salts and their effect on the wheel finish.
You may want to post your questions in this FTE forum:
Brakes, Steering, Suspension, Tires, & Wheels - Ford Truck Enthusiasts Forums
Old Mar 23, 2012 | 10:31 AM
GottaGetIt's Avatar
GottaGetIt
Have always been a fan of American Eagle Alloy Rims. Great quality and rather inexpensive.
Old Mar 23, 2012 | 10:41 AM
F250CCowner's Avatar
F250CCowner
At first I had a set of these in made by Ultra
But they were a PITA to keep clean with all the small nooks. Plus 20's are SOOO expensive for a decent tire. ($480-650 per tire)
I just downgraded size to 17's to these made by MB wheels from Americas Tire Stores
The tires are cheaper to replace down the road ($300-450 per) and I have a greater selection too.
The ride on the 17's is smoother and the tires give me less road noise as well with the BFG AT's then the Super Swampers I had on there.
Old Mar 23, 2012 | 10:49 AM
sergbaja5t's Avatar
sergbaja5t
I like those on the second pic. They resemble the ones I have now just different offset and width!
Old Mar 23, 2012 | 11:24 AM
Gage2502's Avatar
Gage2502
Check out KMC XD series, Dick Cepek wheels they both have lifetime warranty.
I have learned that our Super Duty factory wheels are Hub-centric and most after market wheels are Lug-centric.
Make sure that the load capacity is at least 2500LBS per wheel.
Old Mar 23, 2012 | 12:38 PM
JFH's Avatar
JFH
Thanks for all the replies..good info.
Glad you mentioned the Cepek wheels...I saw some I liked but never heard of that brand. I am trying to find wheels with 0 offset.
Old Mar 23, 2012 | 10:42 PM
Quad Racer's Avatar
Quad Racer
Make sure you use the correct lug for the wheel also. Lug centric lugs are different from stock lugs.
Old Mar 24, 2012 | 12:18 AM
dscabra's Avatar
dscabra
Good point, and keep a set of your factory lugs for your spare.
Old Mar 24, 2012 | 05:32 AM
JMM-MD's Avatar
JMM-MD
One thing to keep in mind is the size tire you are going after as well - if you are going 1 size up you will probably be fine with a wheel that has the same back spacing and/or off set as your stock wheels, and if that is the case you will have lots of quality wheels to choose from, but if you are going multiple sizes up you will want to make sure that you do not rub when turning (usually as something close to full lock of the steering wheel), wheels with off set or additional back spacing may be needed depending on the tire size. You also have to pay attention to the width of the wheel to ensure that and that the width of the wheel is sufficient to handle the tire size. If that is the case your selction of wheels is somewhat smaller.
Good luck!
coldfront
2015 - 2020 F150
Dec 23, 2016 02:02 PM
expoman55
Jan 29, 2014 10:36 AM
kalsc
Jul 3, 2011 10:12 AM
markt1993
6.4L Power Stroke Diesel
Mar 6, 2010 10:34 AM
CounterMaker
Jul 5, 2007 07:17 PM
