Airbag code reset
Old Aug 17, 2004 | 02:58 PM
sas's Avatar
sas
Red face Airbag code reset
I got a code 12 (low battery) on the Airbag the other day so I changed the blown fuse and now have a 52 code (basically saying fuse has been replaced) . Does anyone know if this code will clear itself eventually or will it need to be physically reset.
If it needs physical resetting is this something I can do or do I need the take it to the dealer. It's a 97 Explorer
Old Aug 26, 2004 | 08:32 AM
cdkon's Avatar
cdkon
once the key has been cycles 256 times, it should reset itself
Old Aug 26, 2004 | 08:58 AM
1081's Avatar
1081
...or disconnect the negative battery cable for 10 to 20 minutes, or stop by Auto Zone or someone else with a scanner and have them reset the codes.
