Rather strange problem
Old May 2, 2012 | 02:50 PM
Caldwell F150's Avatar
Caldwell F150
Correct the alternator core is $5
Old May 2, 2012 | 02:55 PM
critterf1's Avatar
critterf1
Tap on it with a hammer while trying to turn it. Sometimes that will break it loose.
Old May 3, 2012 | 06:00 AM
460/5's Avatar
460/5
Zombie Survivalist
odd... ive never had a vehicle with this issue. any time i've done anything with the alternators, everything just comes right apart. 76 F100, 84 F250, 91 F250, 93 explorer. see if you can loosen it a bit, then tap the alternator back and forth down the length of the bolt.
Old May 3, 2012 | 07:04 AM
fellro86's Avatar
fellro86
A heat gun will not apply enough heat, you need to go to mapp gas at a minimum. Sometimes when it is hot you can get motion, and once you have motion, you are home free.
Superblue400
33
Jan 31, 2026 12:13 PM
mustang81
Dec 29, 2014 08:31 AM
Dadsole'FORD
Apr 14, 2011 06:31 PM
denman81
Oct 8, 2007 05:26 AM
dickdollar
Nov 23, 2003 10:07 PM
