92 explorer no reverse
Old Mar 19, 2012 | 11:34 PM
brat1955's Avatar
brat1955
Lost my reverse gear without any warning. I also lost neutral and only have forward gears in my auto overdrive tranny. Any information will be greatly appreciated.
Old Mar 20, 2012 | 06:47 AM
stuart1's Avatar
stuart1
My money is on the forward clutches being seized.
Can you rev the engine freely in Park or does it seem to labour?
Old Mar 23, 2012 | 01:11 AM
brat1955's Avatar
brat1955
When I start it in Park it will lurch a little bit forward like it's already in gear. I have no Neutral whatsoever, only forward gears.
Old Mar 23, 2012 | 01:36 AM
brat1955's Avatar
brat1955
Let me give you the complete story. I took my Explorer in for a smog test and the tranny was working perfectly. The technician backed it out of the parking slot then drove it into the test bay. When they were finished testing it we had to push it out of the test bay. I have not had reverse ever since then and am wondering if this is a typical Explorer tranny problem or could the smog guys have possibly caused this problem. I would appreciate any further input you can provide.
Old Mar 23, 2012 | 05:36 AM
stuart1's Avatar
stuart1
Without knowing what or if anything was or wasn't done any suggestions would be like shooting at a dart board.
Old Mar 24, 2012 | 03:09 AM
brat1955's Avatar
brat1955
Stuart1,
Thanks for your reply and I totally agree with you. Had I saw what went on in the test bay that day perhaps this would be a dead issue.
However, I believe your experience far outweighs mine and I do appreciate your input. Looks like it's time to drop the pan and start investigating. I'll keep you up to date on my end and let you know about them forward clutches.
Take care and thanks again for your time and for sharing your knowledge.
brat1955
Old Mar 24, 2012 | 08:23 AM
Lazy K's Avatar
Lazy K
yes, if it was me, I would drop the pan and look for any debris but also check that the external and internal shift linkage is properly connected.
Good luck.
Old Mar 24, 2012 | 11:51 PM
brat1955's Avatar
brat1955
I've been delaying dropping the pan in hope of an easy cure, however, being as my fluid looks and smells like it's brand new combined with your linkage suggestion that should encourage me to open it up and see what there is to see. Thank you for your input and for your time Lazy K. I shall inform the FTE "family" with either the good or the bad news ASAP.
Thank you all at FTE for your input and for your valuable time.
Respectfully,
brat1955
Ron94150
Jan 8, 2016 08:31 AM
jtcool7
Dec 23, 2015 07:05 PM
Heated
Nov 20, 2004 11:12 AM
Heidi
Jan 15, 2003 06:55 AM
