Sponsored by: Auxito
rear end ID
Old Mar 19, 2012 | 05:06 PM
Little Jon Watts's Avatar
Little Jon Watts
rear end ID
I have a 2000 F-150 with a 9" 3:08 rear end ID tag S824D. Found one at a salvage yard with ID S824A. Is there any difference between the two and will they swap out easily.
Old Mar 19, 2012 | 05:21 PM
steve(ill)'s Avatar
steve(ill)
If the tag on the axle says 3.08 then you should be fine.
Old Mar 22, 2012 | 06:33 PM
Little Jon Watts
Swapped it out today. Apparently the lug studs on the A model are a 12mm thread while the D has larger studs (probably 14mm).
lmoore2422
Oct 31, 2008 06:10 PM
ScottJM
Oct 22, 2003 04:06 PM
blu93gt
Sep 10, 2002 11:39 AM
jaye
Oct 29, 2000 09:53 PM
