What are these?
Old Mar 19, 2012 | 10:37 AM
fixnair's Avatar
fixnair
What are these?
Thought I would post here also since there is not a lot of action on the flathead forum.
Finally getting to put my flathead V8 together and as I sort through the gasket set I find these white pieces of rope packing. It has been three or four years since I tore this engine down and I don't remember seeing where these would go Anybody know what they are and where they go? They are about three inches long and a half inch in diameter.
I already have located the graphite rope packing for the front & rear seals.
Thanks for any help
Old Mar 19, 2012 | 12:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Those are teflon-type rope seals. I assume you have a FelPro gasket set? They give you both the graphite original style, and the teflon ones so you have a choice. I believe the teflon ones are only for the front seal. I used them, no issues. The teflon kind don't benefit from soaking, but should be wetted down before setting the crank.
Old Mar 19, 2012 | 02:51 PM
fixnair's Avatar
fixnair
AH-HA! Gotcha now. Thanks Ross. It makes sense now. They are considerably larger in diameter than the rears and shorter.
49f3dls
Jul 1, 2016 11:13 PM
fixnair
Flathead V8 & Flathead 6
Mar 31, 2012 11:07 PM
mjbll
1997 - 2003 F150
May 18, 2011 10:06 PM
firetruck60
Jan 5, 2010 02:32 PM
Manimal
Jul 4, 2002 03:34 PM
