Batteries.
Old Mar 18, 2012 | 09:23 PM
zach7.3's Avatar
zach7.3
Batteries.
Just wondering what size of batteries i should get for my 7.3, with out doing any types of moding to fit them in.
Old Mar 18, 2012 | 09:28 PM
redman84's Avatar
redman84
Group 65 850 cca or larger
Old Mar 18, 2012 | 09:29 PM
redman84's Avatar
redman84
Correction. Not larger. 850 cca or MORE. Can't edit on mobile.
Old Mar 18, 2012 | 09:31 PM
zach7.3's Avatar
zach7.3
would napa be the best for getting batteries? money is't really a issue just want some reliable batteries.
Old Mar 18, 2012 | 10:03 PM
paddler's Avatar
paddler
9 years from NAPA
Just swapped mine out, NAPA Legend 75, installed Feb 2003. 9 years of no problems, replaced at first sign of starting problems, after 20 degree night unplugged.
Old Mar 18, 2012 | 11:25 PM
oldbird1965's Avatar
oldbird1965
Zach, if money is no problem get XP power batteries from Summit. The are the strongest, most poewerful batteries I've ever had in any vehicle!! Very expensive!!
Old Mar 19, 2012 | 04:09 AM
redman84's Avatar
redman84
Money was definitely an issue for me and unless you go for the ultra top of the line the quality is questionable at best in all the rest so I went for best warranty. Motorcraft BXT65-850 36 month free replacement and 36-100 month prorated.
Yeah those things are awesome. Heard lots of good things about Odyssey batteries as well.
Old Mar 19, 2012 | 10:59 AM
richdawg's Avatar
richdawg
Nine yrs off the NAPA is not to shabby
Old Mar 19, 2012 | 11:53 AM
Hussler's Avatar
Hussler
Don't know if they are the same as Glenn's but mine are from Les Schwab.
XP - Xtreme Power @ 900 CCA each.
Have 5 plus years on them and still going strong.
Old Mar 19, 2012 | 01:20 PM
richdawg's Avatar
richdawg
Mine are Schwab's too, but only 60mos. they will be 6yrs old in Oct.
They are only 675amps cold and 844 @ 32F, I have had no trouble with them so far, but I am saving my $ for new ones because I have found my battery's don't usually last much past the months the are warranted for. If that's the case there running on borrowed time now. I will probably replace them this fall because I just hate it when my battery s fail, it's usually at the worst time possible.
Old Mar 19, 2012 | 02:06 PM
Talyn's Avatar
Talyn
There are only 4 or 5 battery Manufacturers.
So some of the batteries you all are buying from different places are the same thing. =)
I grabbed 65's I think from Napa.
Old Mar 19, 2012 | 02:54 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Glenn was it XS Power? Cause i found this battery at summit, its 1,360 CCA and costs $370 .
Old Mar 19, 2012 | 05:33 PM
richdawg's Avatar
richdawg
IIRC that is the one Glenn got, to expensive for my blood, x2 = 740 ouch, I hope they last a long time.
Old Mar 19, 2012 | 05:42 PM
DarkStarMedia's Avatar
DarkStarMedia
This is actually a common mis-conception... yes there are 3-4 battery manufacturers that make 90% of the worlds lead acid batteries.... But... private labels (Walmart, CSK, Autosone, etc.) can select various options like a menu to affect warranty length and cost....
So ... they can be a little different depending on the options.
Also, batteries of a given level tend to be close enough to not matter.
Example: most of the chain autoparts stores will have near enough the same batteries if they have the same warranty.
The Manufacturer batteries (BMW, Motorcraft, Honda, etc) tend to have the higher end options (heaver plating, thicker case, heavier straps, composite isolators, etc).
Richard
EDT: BTW, I think the main manufacturers are Interstate, Exide, Panasonic, and there is one in Taiwan... Bosch used to make their own but I think they now subcontract to one of the others. Note that this is all from memory.
Old Mar 19, 2012 | 05:52 PM
terryknight's Avatar
terryknight
i'm running reman batteries from a local store 1050 CCA. going on year number 4. and at less than half the price of a new one
