Offroad & 4x4
dana 60 swap
Old Apr 27, 2003 | 10:50 PM
superswamper's Avatar
superswamper
dana 60 swap
i was wondering how hard it would be to swap a dana 60 into an 76 f150 radius arms suspension, has anyone done it which what's the best donor truck so on and so forth
Old Apr 28, 2003 | 12:17 AM
Ryan50hrl's Avatar
Ryan50hrl
dana 60 swap
well you'd need to find a set of the triangular mounts to weld onto the axle...if you do that it should bolt right in
Old Apr 28, 2003 | 01:59 PM
proeliator's Avatar
proeliator
dana 60 swap
78 & 79 are the earliest good years for front D60s. The 80s and up are good to but you can get a little more turning radius from the 78/79s. The pre 78s have smaller axles w not more strength than a D44.
Old Apr 29, 2003 | 08:13 AM
Redneck 83's Avatar
Redneck 83
dana 60 swap
Those wedges you need can be bought at jamesduff.com in their now products section.
Old Apr 29, 2003 | 12:53 PM
broncoholic's Avatar
broncoholic
dana 60 swap
DAMN! Why couldn't I find any wedges like that when I did my conversion. I spent a couple days cutting 1/4" plate steel and fabricating wedges for my D60. Aside from those wedges, the only other thing needed is a piece of box tubing to fabricate the track bar mount. I did my conversion with a 79 D60. I had to raise the front shock mounts to clear the tie rod. Check out my gallery for some pics.
Old Apr 29, 2003 | 04:08 PM
proeliator's Avatar
proeliator
dana 60 swap
Yea, but not only is it cheaper but its also way the hell cooler when you can say "I made it myself".
Old Apr 29, 2003 | 07:58 PM
mustange70's Avatar
mustange70
dana 60 swap
How can a guy tell if he has a dana 60 under a 78-79 1/2 ton? We got 2 of last fall (one was in the middle of being restored but the guy ran out of money in a divorce) and the are extremely good trucks.
Old Apr 29, 2003 | 11:23 PM
proeliator's Avatar
proeliator
dana 60 swap
We're talking about front axles and 1/2 tons never came with Dana 60s. But in anycase, I think you are talking about the rear axles which should be a Ford 9". As with all axles, check your BOM if unsure.
Old Apr 29, 2003 | 11:26 PM
mustange70's Avatar
mustange70
dana 60 swap
I couldn't remember if the 1/2 tons did or not. But my dad does have a 1/2 ton that has a dana 60 in the rear and it has the ford 5 bolt wheel pattern.
Old Apr 29, 2003 | 11:43 PM
proeliator's Avatar
proeliator
dana 60 swap
Never seen or even heard of a 5 lug D60 for 1/2 tons. Then again, I'm no expert on 1/2 tons and have never owned one. Is that full or semi-floating?
Old Apr 29, 2003 | 11:52 PM
RCrawler's Avatar
RCrawler
dana 60 swap
Mid 60's and early 70's 1/2 tons had 5 lug, semi floating 60s.
Here's some in depth Dana 60 info
Dana 60 tech
Jason
Old Apr 30, 2003 | 09:40 AM
RRMike's Avatar
RRMike
dana 60 swap
Yeah,
Everybody around here calls them a "60 dash 2"
Old Apr 30, 2003 | 11:11 AM
proeliator's Avatar
proeliator
dana 60 swap
Thats what I get for never looking at an axle with less than 8 lugs. Yea, I'm over on Pirate allot...Billavistas bible is awesome.
Old Apr 30, 2003 | 09:27 PM
78f3504x4's Avatar
78f3504x4
dana 60 swap
I've read that 78-79 Ford 60s are the best for radius-arm setups because they have a 32" (or so) leafpad-to-leafpad compared to the 86-97 Ford Dana 60 which has a 36"(or so) measurement. The older Dana gives you more room for the radius arms.
Old Apr 30, 2003 | 09:56 PM
fordzgal's Avatar
fordzgal
dana 60 swap
Speaking of Dana 60's anyone know where I can get my hands on one?? Shhh shhh a father's day present for my hubby...let me know I am in Washington state...
