460 vs 351
Old Mar 19, 2012 | 09:31 AM
GNR22's Avatar
GNR22
The diesel truck will get a lot better mpg, and the 7.3L will last 300k - 400k, as opposed to the 7.5 lasting 100k-200k. The diesel truck is also good for torque, especially 94.5 and after being powerstrokes. I guess there should be some explanation here.
The 7.5L is pretty much the same through these model years, no huge differences, however there are some Mass Air variations over in california that would be killer to get a hold of.
The 7.3L was offered with no turbo for a while, then was offered with a turbo and then the powerstroke was brought in half way through 1994.
The 5.8L was offered as a non roller speed density motor, and then a roller motor with speed density or mass air.
The powerstroke, the mass air roller 351w, and the mass air 460 would all be the best variations in comparison to themselves. with that said, gearing still makes a difference. but the powerstroke will outpull the 460, which would outpull the 351. If they were all in stock form. If you can get a hold of a powerstroke for cheap, I would jump on it.
Old Mar 19, 2012 | 12:21 PM
thechief66's Avatar
thechief66
I've owned both a 351 & a 460 in similar trucks (95 F150 4x4 vs. 96 F250 4x4).
Around town & just cruising down the highway the 351 is OK, but towing?
Forget it, get the big block!
Old Mar 19, 2012 | 12:26 PM
Big_Al59's Avatar
Big_Al59
Test drive all of the different engines and see what you think. There's a ton of the gas vs diesel threads already, look in here, the psd forums, heavy duty forum etc. Enough reading to keep ya busy for hours. I might think a psd/5spd 4*4 was the greatest truck ever but you might think its an overpriced,stinky, noisy, high maintainence pos. Go drive some and see what ya like.
Old Mar 19, 2012 | 01:52 PM
blacklab1's Avatar
blacklab1
Sounds good except it's a 3 hour drive to look at anything.
That's why I'm trying to narrow the search.
Old Mar 19, 2012 | 04:04 PM
redmondjp's Avatar
redmondjp
I'd go for the 460 but I'm biased - I have one. With the bigger motor, you don't have to get into the throttle as hard to move down the road, everything else being equal.
As for gas vs. diesel, stay away from the diesel unless you drive 10K+ miles a year. The repairs on a Powerstroke, although not often, can be very expensive. You can easily burn up several years' worth of fuel savings with one repair. Not to mention the 15-quart oil changes! I'm just being realistic here, I've had both gas and diesel vehicles, and each has its purpose.
Old Mar 19, 2012 | 04:36 PM
burnout400m's Avatar
burnout400m
Powerstrokes are also much more expensive than gas truck to purchase in the first place. The older non-turbo diesels are much closer in price and will probably have enough power to suit your needs but they have less power than the 460.
Old Mar 19, 2012 | 11:48 PM
Scooter70's Avatar
Scooter70
I've got a 460. Big Block, need I say more. I use my 460 everyday. Buy what you like. I can tow anything thrown at me, cheap insurance,cheap parts and did I tell you I got big block. Now where 's that Hemi....
Old Mar 20, 2012 | 10:24 AM
therifleman556's Avatar
therifleman556
Buy a pre-stroke 7.3. Cheaper than dirt, easy to fix, good power (maybe not as much high end as a 460) and easy 15 to 20mpg (4:10 gears and 3:54 respectivley). Hows that for muddy water!
Old Mar 20, 2012 | 10:40 AM
05victorylly's Avatar
05victorylly
This is good advice ^^^. I went with the 460 because it is a little more powerful and I had an easier time finding a 460 than the 7.3.
But if your going to drive it alot, I would definitely put a lot of consideration into a 6.9/7.3 diesel. I have a newer 3/4 ton diesel that gets great mpg so it was not as important to me to have great fuel economy. I was looking for the most power, towing/hauling ability in stock form and in late 80's and early 90's i believe the 460 is the most capably out of the box until you get to power strokes.
Old Mar 20, 2012 | 11:30 AM
Conanski's Avatar
Conanski
Generally.. there ain't no replacement for displacement though you can cheat that rule with forced induction. It's also pretty easy to message a 351 up to stock 460 power levels and the 5.8 can return better milage than the bigger motor.. though with the larger/heavier trucks that advantage can be reduced to nil or even reversed in favor of the 460. So like everything I think it depends upon what trucks are available.. their vintage and powertrain setup does effect performance and fuel economy, and it also depends how the truck will get used. If the OP isn't ever going to haul anything too big or heavy then a 5.8 truck will be sufficient, though if he were to find a 460 truck with 3.55 gears and an OD trans he wouldn't be sacrificing much if any fuel milage for increased towing power.
Old Mar 20, 2012 | 02:22 PM
rambuck's Avatar
rambuck
I'd strongly suggest the 351W for a small camper. I pull steel horse trailers with mine and other than just a drop in fuel economy, my F250 hauls without any sweat. The 460 is just for major constant towing, like everyone has said. I'd dread driving my truck (since it's also my daily, unlike your purchase) if it had a bigger V8 in it. Plus you never know when you'll use your truck for lighter loads than a camper but too cumbersome for your Explorer.
Old Nov 20, 2024 | 01:01 PM
gabrielbelliott's Avatar
gabrielbelliott
4th Gear
This is super helpful for my own issue, thank you
b_man360
Mar 7, 2009 10:03 AM
BKB
May 31, 2006 10:57 PM
ttypeturbo
Jun 27, 2004 11:04 PM
Peter 460
All Things Towing
Nov 26, 2003 10:24 AM
stover007
Apr 10, 2003 02:18 AM
