Ranger Electrical Gremlin
Old Mar 18, 2012 | 09:59 AM
Joejoecat's Avatar
Joejoecat
Its a 1999 Ranger XLT ,4x4 ,4.0 , Auto. When I press on the brake pedal with the driver side turn signal on the signal quits blinking at the dash and at the tail light. It works ok on the passenger side.I checked all bulbs and they are fine. The turn signal flashes as long as the break pedal is not depressed. Any thoughts ? Thanks in advance
Old Mar 20, 2012 | 09:26 PM
wp120470's Avatar
wp120470
Check for a bad groung in the tailight assembly or maybe a bad bulb on that side, but most likely it is a short in the driver side tail light.
Old Mar 22, 2012 | 08:39 AM
tomw's Avatar
tomw
I'd bet on a bad mult-function switch. The switch separates the non-blinking brake light side from the blinking side so the brake light will come on solid, while the other side blinks.
Check for brake light operation and then for individual flasher operation. If both work, then the switch is the only thing I can think of that does that function.
tom
Old Mar 23, 2012 | 07:48 PM
Aune163rd's Avatar
Aune163rd
x2 with what tomw is saying, sounds like a bad switch.
Old Mar 24, 2012 | 03:32 AM
mfp4073's Avatar
mfp4073
doesnt this stuff pass through that connector on the rear floorboard that gets corroded easily?
EDorado
May 22, 2017 08:41 PM
Dozier4life
Dec 2, 2016 10:11 PM
sdreed52
Oct 11, 2016 09:39 AM
shottheif
Jan 31, 2011 09:58 AM
tmcalavy
Sep 2, 2001 05:02 PM
