Hi well I have a 99 ford ranger xlt 4.0 ohv basically it sputters so bad while driving it sounds like a dumptruck but it all started when I changed my o2 sensors but in doing so I broke my heater control valve and when I was going down the road it started sputtering well it started sputtering so I checked the o2 sensors there good and I changed the heater control valve. But nothing so I changed my coil pack spark plugs and wires but still nothing. But on my reader it says cylinders 2,3, and 4 are misfiring and bank 1 and 2 are running lean plus it has a bad aroma of gas in the engine compartment but when it idles its somewhat smooth but when I'm driving it its horrible the sputtering is so bad it takes awhile to get up to speed plus I'm only getting 100 miles to a whole tank that's like 8 or 9 mpg I need to fix this soon. this is my only transportation so if anybody knows what's goin on please I'm all ears thanks
Well yes it was showing codes for the upstream o2 sensors both banks and yes the engine light came on and still is on but not sure bout air metering but I haven't seen any hoses loose or disconnected
