Check engine light for HO2S
Old Mar 21, 2003 | 02:56 PM
oldstylefseries's Avatar
oldstylefseries
Question Check engine light for HO2S
Fellas,
New guy here. Basically a list lurker unless I recognize a problem that I've had and I can help. I am getting frustrated here. Been chasing a problem on my dad's truck. 96 f-150 (OBD II), 300 I6, and an E40d. Get a check engine light. Pull the codes ( I'm lucky enough to have access to a scanner) and find that the codes are for the HO2S monitors. Checked the obvious (fuses, broken wires, O2 sensor replacement.) Have 12 volts on the 2 white wires (O2 heater wires), but STILL get a check engine light. I'm out of ideas. Anybody else ever run into this?
Thanks,
Tim in Detroit
Old Mar 21, 2003 | 07:52 PM
Racerguy's Avatar
Racerguy
You've tried new sensors?
The sensors just read what the engine is doing, rich or lean. You can have a problem upstream of the sensors and get a code for them. It's not neccesarily an O2 problem. If you have a misfire the sensors see extra oxygen in the exhaust and think it is lean so the PCM richens up the mixture. If you have a dirty MAF sensor or one that isn't reading correctly you can have O2 codes. Same with fuel pressure. Or a vacuum leak. Anything that can make the engine run rich or lean can cause an O2 code.
I think I'd start by checking for vacuum leaks, particularly the throttle body gasket and clean the MAF sensor.
Old Mar 21, 2003 | 08:17 PM
oldstylefseries
Talking Check engine light for HO2S
Thanks for the reply, but I'm not referring to the OPERATION of the O2 sensors, but the HEATER circuit for the O2 sensors. The o2 sensors work fine. Just the heater circuit for the O2 sensors is throwing codes. There are NO codes for the O2 sensor function (rich/lean).
Thanks,
Tim
Old Mar 21, 2003 | 10:56 PM
Racerguy's Avatar
Racerguy
oooooh ok
The O2 heaters are switched on their ground side through the PCM. The PCM is the only place they are connected.
If you can post the codes you got I can probably post the pinpoint tests out of the manual.
Old Mar 22, 2003 | 12:31 AM
steve83's Avatar
steve83
The heater side of the HEGO isn't connected to the computer, and therefore, doesn't throw codes. It's just wired hot thru the ignition switch to the Ppl/Or wire, which also powers several other key-on devices.
The codes you're getting are for the sensor part of the HEGO.
Old Mar 22, 2003 | 09:20 AM
Racerguy's Avatar
Racerguy
On OBDII systems the PCM does monitor the heaters and will set codes.
Old Mar 22, 2003 | 09:42 AM
StrangeRanger's Avatar
StrangeRanger
And there's 3 of them, one on each manifold and 1 between the cats. Be sure you check the voltage to all 3.
Old Mar 22, 2003 | 10:31 AM
steve83's Avatar
steve83
Oops - you're right. Ignore my previous post. It applies to EEC-IV, but not to OBD-II.
