1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Help Picking A Truck!
Old 03-17-2012, 09:03 PM
jetpilot2's Avatar
jetpilot2
jetpilot2 is offline
I had this in the tow section and zero response, so thought it may be more appropriate to ask here.
This is really a multi-faceted question, but here it goes...
I'm looking at getting a 40'-50' gooseneck trailer w/living quarters in the front that will be pulled mostly on the east coast with an occasional trip to the west cost (couple times a year). The couple I have looked at have been in the 18K and 21K GVWR range. After doing some reading/research on here, it looks like an F-450 might be in order?
Although a 2012 would be nice, I'm leaning more towards used. There are a ton of 08's, some with low miles, some with more. I am totally unfamiliar with the 6.4 or 6.7 other than the "horror" stories I have read about fuel systems. I'm wrestling with the decision on the best course of action to take. The "conventional" wisdom would dictate I look for a truck with lowest miles for the best price, but I'm wondering if a "proven" truck (with a few more miles that would have revealed early problems) is not the prudent choice here. There seems to be some decent deals on '08 6.4s, but not sure if there is a reason for that or not (other than the obvious). Are the early 6.4s any good, or were there problems early on in its life, much like the early 6.0s? Should I be looking for late model 6.4s? Is the 6.7 exponentially better that I should consider spending a little more to get into an '11?
Fire away!!
TIA
Old 03-17-2012, 09:49 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Tia what is the dry weight of the trailer it would help us out alot with what you are trying to find out? Also how old are you willing to go as far as age of the truck? I personally am not familiar with diesels but do know that alot of people like the 7.3L powerstroke.
Trav
Old 03-17-2012, 10:24 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
To be honest, what you really need for towing something that size is a medium duty tow rig, not a pickup.
Old 03-18-2012, 04:35 AM
jetpilot2's Avatar
jetpilot2
Actually, I have been looking at those as well, but not sure it's what I want to be driving around town when I'm "unhooked" out of town.
Old 03-18-2012, 04:38 AM
jetpilot2's Avatar
jetpilot2
Trav
Trav,
Not exactly sure what the dry weights are, sorry. I just have the GVWR for worst case.
I LOVE the 7.3, believe me, I'm just not sure if it's my best bet for this tow.
Old 03-18-2012, 09:29 AM
redford's Avatar
redford
redford is offline
Received 1,611 Likes on 941 Posts
There is no vehicle that would be able to tow 21-23000 pounds and can easily drive around town.
An F-450 would be capable of doing both and is probably your best compromise. Depending on where you live, a crew cab, 8 foot bed, dual rear wheel truck can be a hassle. For instance, I would not want to drive one in Boston.
Depending on how often you tow, you might want to consider something heavier than an F-450, such as an F-650 conversion or a CXT.
Old 03-18-2012, 10:31 AM
jetpilot2's Avatar
jetpilot2
Understood Redford!
It will towed approx. 25 weekends/weeks a year. A 450 was first choice due to the "compromise" you spoke about.
I browsed a few F-650s, but they all seem way to tall to accommodate a gooseneck and most looked to for show.
Thanks,
George
Old 03-18-2012, 03:46 PM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
RCKYMTN-PSD is offline
Just another opinion but my dad has a 350 dually with a 7.3 and a 08 450 with the 6.4 and the 350 has a half inch of dust on it... if you know what I mean. Those 450s are worth checking into, much nicer to drive around daily than a 650 of course
Old 03-18-2012, 04:15 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
George, if you're not specifically needing a pickup, another option would be an F-450 or 550 chassis cab with either a towing / hauler type of bed or a flatbed.
Old 03-18-2012, 04:56 PM
Redneckfordf2502002
Originally Posted by jetpilot2
Trav,
Thats ok I don't know much about diesels so I will let the other guys help you out on this one. I do know a load like that is probably best for a F450 maybe even a F550 because those trailers some times will wear out something that can just do it where as a truck that will do it if you know what I mean.
Trav
Old 03-18-2012, 08:23 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
They do make some nice 450/550 tow rigs that would probably handle a trailer of that size just fine. A flatbed with a gooseneck hitch would work just as good as one of these custom tow rigs too, and would probably cost quite a bit less.
I would still be more comfortable towing something that size with a MDT like an F-650 or the International I posted above. Maybe that's just because I am used to driving that type of truck. This is the truck I drive every day for work:
Old 03-19-2012, 01:48 AM
jetpilot2's Avatar
jetpilot2
Ooph!!
I just reread my last post. Please forgive me, it was made after a 17-hour day on VERY little sleep!
Anyways, thanks for all the replies and keep them coming.
Rocky,
Good to know!
PS72,
I don't specifically need a pick-up, just thought it would come in handy ocassionally. I'll see what I can find in that type of set-up.
Trav,
I hear you.
KD,
Nice rides!!
Old 03-19-2012, 03:49 AM
jetpilot2's Avatar
jetpilot2
Any info./advice on 6.4 vs. 6.7, or should I poke my head in the diesel section?
Workingitout
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-17-2017 03:09 PM
preloader
2017+ Super Duty
07-04-2017 09:07 AM
Ruby350platinum
2017+ Super Duty
02-08-2017 08:38 PM
lj_ford
06-05-2016 04:36 PM
08Adrenalin
Car/truck Buying Advice
09-04-2015 03:10 PM
Quick Reply: Help Picking A Truck!
