Steering Rebuild
Old Mar 17, 2012 | 01:19 PM
mountainsportsman's Avatar
mountainsportsman
Thumbs up Steering Rebuild
I did a search when I started this process and found some, but not much of the information I needed. Just throwing this up so that in future searches people will find me and I can be helpful.
I removed and disassembled the steering column, steering shaft, steering gear and pitman arm. Sent the gear to be rebuilt by Redhead Steering in Seattle. One day turn around $299. Great customer service. I looked into having the column rebuilt...$400+ Instead I told myself "how hard can it be?" Not too hard really. I used a diagram, then just remembered what I did on reverse. Ordered new parts to replace the worn parts from LMC, and less than $200 later I have a basically new steering column setup. Tight and awesome steering...added a drop pitman to replace the stock pitman that the PO torqued at an angle to make up for the lift. Less bind and wear and tear over time for sure with the new correct setup!
Shoot me a note if you are driving a 78 or 79 with 1/3 steering wheel turn worth of sloppy play like I was and are looking for advice. While I'm no expert, I'm happy to do what I can and share my lessons learned!
-Pete
JNye
Jan 24, 2019 04:03 AM
LARIAT 85
Jul 31, 2008 02:57 PM
farmnaggie
Oct 14, 2007 11:08 PM
frdnut
Jul 29, 2006 10:46 AM
